Custom Fields
To execute this report, you should have the following access rights to the objects:
- View custom fields;
- View admin fields;
- Request reports and messages.
A report with the Custom fields table can be executed for units, unit groups, users, drivers, driver groups, trailers, and trailer groups. The table is a list of names and values of custom fields specified in the properties of the object for which the report is executed.
You can specify custom fields in the properties of:
- unit;
- unit group;
- driver;
- trailer.
In the filer of the table settings, you can select the field type that should be shown in the table: all, general, admin, and also specify the field mask.
The possible columns of the table are listed below.
| Column | Description |
| Name | The name of the field. |
| Value | The value of the field. |
| Notes | An empty column where you can leave your own comments after printing or exporting the report. |
To get a report on a group of units, drivers or trailers, enable the Detalization option in the table settings. If the Group itself option is disabled in the table settings for a unit group, then the report shows customs fields of each unit from the group. If the Group itself option is enabled, then only the custom fields of the group are shown.
A report on a unit group with the Group itself option enabled can only be executed for one group. If several groups are selected in the Object parameter, then the data is shown only for the group you specified first.
