Trips
The Trips report shows the intervals of movement with the indication of time, location, and other parameters such as speed, mileage, fuel, and many others. The intervals of movement (trips) are detected according to the parameters set on the Trip detector tab and adjusted for each unit individually.
The table can include the columns described below.
ColumnDescription
BeginningThe date and time when the trip began.
Initial locationThe address where the device was at the beginning of the trip.
Initial coordinatesThe geographical coordinates of the location of the unit at the beginning of the trip (in decimal degrees).
EndThe date and time when the trip ended.
Final locationThe address where the unit was at the end of the trip.
Final coordinatesThe geographical coordinates of the location of the unit at the end of the trip (in decimal degrees).
DriverThe name of the driver (if assigned).
TrailerThe name of the trailer (if assigned).
Passengers countThe number of passengers transported within a trip.
DurationThe time interval of the trip.
Total timeThe time from the beginning of the first trip to the end of the last trip.
Off-timeThe period of time passed from the end of the previous trip to the beginning of the current one (defined beginning from the second trip).
Following off-timeThe period of time passed from the end of the current trip to the beginning of the next one.
Engine hoursThe time of the operation of engine hours during the trip.
MileageThe distance travelled by the unit during the whole trip.
Mileage (adjusted)The mileage taking a coefficient set in unit properties (the Advanced tab) into account.
Urban mileageThe distance travelled in the urban area.
Suburban mileageThe distance travelled in the suburban area (that is at high speed). The urban/suburban speed line is indicated in the Unit properties on the Advanced tab (the Urban speed limit setting).
Initial mileageThe value of the mileage sensor at the beginning of the trip. If there are no sensor readings, the initial value is calculated by the mileage counter from the beginning of the report interval to the first trip.
Final mileageThe mileage sensor value at the end of the trip.
Toll roads mileageThe distance that the unit passed during the trip on the roads on which the Platon system is used.
Toll roads costThe sum of money (in RUB) for the toll roads mileage calculated on the basis of the covered distance and the Platon tariff.
Avg speedThe average speed within the trip.
Max speedThe maximum speed registered within the interval.
Trips countThe number of trips at the interval (can be useful if you have enabled grouping by years/months/weeks/days/shifts or if you run the report for a unit group).
CounterThe counter sensor value.
Initial counterThe counter value at the beginning of the trip.
Final counterThe counter value at the end of the trip.
Avg engine revsThe average rate of engine revolutions.
Max engine revsThe maximum rate of engine revolutions.
Avg temperatureThe average temperature value registered in a trip.
Min temperatureThe minimum temperature value registered in a trip.
Max temperatureThe maximum temperature value registered in a trip.
Initial temperatureThe temperature value at the beginning of a trip.
Final temperatureThe temperature value at the end of a trip.
StatusThe unit status registered during the current trip (if there are several, the first one is displayed).
Cargo weightThe average value of cargo weight during the trip.
Messages countThe number of messages that formed the trip.
ConsumedThe volume of consumed fuel detected by any sort of fuel sensor. If several such sensors are available, their values sum up.
Consumed by...The volume of consumed fuel detected by a fuel sensor or calculated by math or rates.
Rates deviation by...The difference between consumed fuel detected by a sensor and consumption rates. If a number in this cell is negative, it means the detected consumption does not exceed the indicated rates.
Avg consumptionThe average fuel consumption by any sort of fuel sensor. If several such sensors are available, their values sum up.
Avg consumption by ImpFCS/AbsFCS/InsFCS/FLS/math/ratesThe average fuel consumption during the trip detected by one of the methods mentioned above.
Avg consumption in idle run by...The average fuel consumption during the idle run.
Avg mileage per unit of fuel by...The average fuel consumption (per one liter/gallon) detected by one of the methods mentioned above.
Initial fuel levelThe fuel level at the beginning of the trip.
Final fuel levelThe fuel level at the end of the trip.
Max fuel levelThe maximum fuel level during the trip.
Min fuel levelThe minimum fuel level during the trip.
PenaltiesThe penalties calculated for the adjusted Eco driving criteria.
RankThe received penalty points converted into a grade using a 6-point scoring system.
Avg value of custom sensorThe average value of a custom sensor during the trip.
Min value of custom sensorThe minimum value of a custom sensor during the trip.
Max value of custom sensorThe maximum value of a custom sensor during the trip.
Initial value of custom sensorThe custom sensor value at the beginning of a trip.
Final value of custom sensorThe custom sensor value at the end of a trip.
The availability of the Toll roads mileage and Toll roads cost columns is stipulated by a special service. Contact your service provider if you want to use this functionality.
See data in reports to find more about formatting time, mileage, fuel, etc.
Also, the interval filtration by duration, mileage, engine sensor, engine hours, speed range, stops, sensors, driver, trailer, and geofences/units can be applied to this table.
The tracks of the trips can be displayed on the map. To make use of this feature, in the report template, select the options connected with the rendering of tracks on the map.
