Route ACL
Route access rights are described below.
View item and its basic properties
Activating this right allows seeing a route in the Routes panel.
Manage access to this item
Allows you to transfer the right to the routes to other users. Moreover, this right allows you to see the route not only on the Routes tab but also on the map. The user can edit the route (add, delete checkpoints, and change their radius), add schedules, show a list of rides for the route, and copy the route.
Delete item
Allows deleting a route.
Rename item
Allows renaming a route.
Query reports or messages
Allows receiving reports containing data about the available route.
