Managing Routes
Routes are listed in alphabetical order. To quickly find a certain route, use the dynamic filter above the work list. Type the route name or part of the name into this field.
Below the dynamic filter, there is a drop-down list where you can select the way to display routes in the work list.
| Option | Result |
| Routes | Only routes are displayed (without any sublevels). |
| Schedules | The routes are displayed with their schedules. |
| Check points | The routes are displayed with their check points. |
| Active units | The routes are displayed with the units that are currently performing them. |
The following icons are used on the Routes tab:
: edit the selected route (change its name, description, color, and the radius of the check points);
: add a new schedule for this route;
: show the list of rides for this route (finished, in progress, pending, estimated, aborted);
: create a ride for this schedule manually;
: copy the selected route or schedule (create a new route or a schedule on the basis of the selected one);
: delete the selected route or schedule;
: the automatic creation of rides for this schedule is enabled (click to disable);
: the automatic creation of rides for this schedule is disabled (click to enable);
: the automatic creation of rides for this schedule is impossible because the schedule type is not Relative to day.
To display a route on the map, check the box next to its name and make sure the Routes layer is activated. To center the map on the route, click on its name.
The names of the check points are displayed on the map by default. To hide them, deactivate the Display names of routes’ check points on map option in the user settings.
