Top Panel
In the upper panel on the left, there is the logo of the tracking services provider, and on the right, there is the menu setting button and the username under which the user logs on.
The main menu of the program occupies the central part of the top panel. It contains different elements depending on the settings applied and also on the modules provided.
User menu
In the right corner of the top panel, the user’s login is displayed, under which the authorization has been made. Meanwhile, one more login can be specified in parenthesis if the main user logged in on behalf of the other.
When clicking on the user name, an additional menu appears. It contains the following options.
**User settings
**Opens the user settings dialog for viewing and/or editing.
**Manage applications
**Opens the manage applications dialog.
**Locator
**Opens the locator’s dialog.
**Import/Export
**Enables to transfer the settings of units, users, resources’ contents (refer to Import and Export).
**Help
**Help request. Can be unavailable.
**Technical support
**Technical support request. Can be unavailable.
**Logout
**Click here to log out of the system (session termination).
Help and Support are links to third-party Internet resources containing either documentation or technical support. By default, they are disabled. You can enable and configure them in the administration system.
Information notices
Information notices from the service manager can appear in the top panel under the username, as well as notices on the number of days left before blocking the tracking system (if specified by the tariff agreement).
See also
