Using Trailers
Online tracking:
  • Trailers can be displayed in the Monitoring panel.
  • Trailers can be displayed in additional information of the unit if this option is activated in the General settings tab of the User settings dialog box.
  • Trailers can be displayed on the map. Even though they do not have their own coordinates, the location of the trailer can be defined with the help of the unit to which the trailer is bound. To see the trailer on the map, check the box with its name in the left column in the trailer panel. If the trailer is bound to the unit, it is displayed in the lower right corner of the unit’s icon. If the trailer is not bound to the unit, the last known position is displayed.
In notifications:
  • You can configure a notification to be informed when a trailer is bound to a unit or unbound from it.
  • Using notifications, you can also unbind trailer automatically, for example, when entering the destination point.
In reports:
  • Many tables (such as Trips, Geofences, Parkings etc.) can have a column, which shows whether the trailer was bound to a unit at a certain interval or not.
  • As a part of the Advanced reports module, you can generate tables for individual trailers and trailer groups. The Bindings and Custom fields tables are currently available.
