Code examples
In this section, you can find examples of how to use API methods. In the examples, https://hst-api.wialon.com is used as the Wialon Hosting request server, and wialon_test is used as a demo login. To test an example, copy it to the address bar of your browser. Note that the session ID is a required parameter which you can obtain from a successful login operation.
