Getting an access token
Gurtam team has created a more secure way of authorization similar to oAuth. The previous core/login way of authorization was valid until 01 Oct 2015. All clients who implemented their own login forms or demo access links should change them to correspond to the new authorization way.
For now, two forms exist: an extended and a simplified one.
Extended form
The extended form is generally useful for mobile and other apps.
Copied!
http://<host>/login.html
Copied!
http://<host>/login.html?client_id=...&access_type=...&activation_time=...&duration=...&lang=...&flags=...&user=...&redirect_uri=...&response_type=...&css_url=...
Parameters
All the parameters are optional.
Name Description Default
client_id Name of the app/site/client for which you want to generate a token. Site name (title).
access_type token flags 0x100
activation_time Token activation time. UTC time in seconds: 0 - now. 0
duration Token duration in seconds. Set to 0 for unlimited duration.
If the token is not used for 100 days, it is automatically deleted.
2592000
(30 days in seconds).
lang Language (en, ru, etc.).
flags See below. 0
user Username. Will be in the login field.
redirect_uri URL to redirect and forward authorization results. login.html itself
response_type The response will contain the token (token) or AuthHash (hash). Token.
css_url URL to CSS-file with the specified styles for login_simple.html.
Flags
Flag Description
0x1 Return user_name in the response.
0x2 Return in the response:
  •  client_id
  • access_type (if response_type=token),
  • activation_time,
  • duration,
  • flags,
  • response_type,
  • svc_error.
0x4 Return all the parameters from the request excluding the reserved ones (client_id, response_type, access_type, activation_time, duration, flags, login, passw, redirect_uri, p, app, sign, hash, remote_hash).
After successful authorization, a redirect to redirect_uri occurs, and the following GET-parameters are transferred:
  • access_token (72-symbol token which may be used for authorization in future);
  • user_name (authorized username, if 0x1 flag was stated before token generation).
In case of an authorization error, a redirect occurs to the login form itself, the specified error is shown and the following GET-parameters are transferred:
  • svc_error (error code);
  • client_id;
  • access_type;
  • activation_time;
  • duration;
  • flags.
After getting a 72-symbol token, you can use it in your apps for authorization with the method token/login:
Copied!
svc=token/login&params={"token":"<access_token>","operateAs":"<optional_sub_user>"}
Simplified form
The form is used for simple embedding into sites via iframe to quickly access one or more monitoring sites after authorization. By default, a link to the monitoring site will be created. Also, you may add links to other sites (using cms_url, mobile_url, demo_url).
Copied!
http://<host>/login_simple.html
Copied!
http://<host>/login_simple.html?lang=...&cms_url=...&cms_title=...&lite_url=...&mobile_url=...&demo_title=...&demo_url=...&title=...&css_url=...
Parameters
Name Description
cms_url URL to a CMS Manager site (for example, http://cms.wialon.com). If stated, it will be added to the list of quick jump sites.
cms_title Link title for CMS Manager.
mobile_url URL to a Wialon mobile app site (for example, http://m.wialon.com).
mobile_title Link title for the Wialon mobile app.
title Link title for the monitoring site.
demo_url URL for demo access (for example, http://hosting.wialon.com/?token=).
demo_title Link title for demo access.
css_url URL to a CSS file with the specified styles for login_simple.html.
