Error codes
If the server can’t complete an API request, it returns a JSON response containing an error code:
{"error":<code>}
The HTTP status of such a response is 200 OK, the same as for a successful request. To find out whether a request succeeded, check the body of the response, not the HTTP status.
For some errors, the response also contains the reason field which explains the cause of the error:
{"error":<code>,"reason":<text>}
General error codes
| Error code | Description | reason field value |
| -100 | Internal error (network timeout). | |
| -101 | Internal error (wrong network response). | |
| 0 | Successful operation (for example, for logging out it’s a successful exit). | |
| 1 | Invalid session. | |
| 2 | Invalid API service name. | |
| 3 | Invalid result. The type library plugin isn’t enabled, the AVL Server item isn’t found, or the file isn’t found. | |
| 4 | Invalid input. The request contains a wrong parameter value or a wrong combination of parameters, or an object ID doesn’t identify an existing object within a container the user can access. | VALIDATE_PARAMS_ERROR: <text>: the parameters don’t match the scheme expected by the method, where <text> is the expected scheme. Returned by the methods which use the general parameter check.PARAMS_ERROR: <text>: the parameter check of the method failed, where <text> describes the cause.DRIVER_NOT_FOUND: the specified driver isn’t found in the resource (resource/driver_actions_list, resource/driver_actions_cleanup, resource/driver_actions_register, resource/bind_unit_driver).ROUTE_NOT_FOUND or ORDER_NOT_FOUND: the specified route or order isn’t found (order/route_update, order/optimize, order/update).BATCH_INVALID_INTERNAL_REQUEST index=<i>: one of the elements of the request array isn’t a valid method, where <i> is the position of this element starting from 0 (core/batch).BATCH_MAX_INTERNAL_REQUESTS_EXCEEDED count=<n> max=<max>: the request contains more methods than allowed, where <n> is the number of methods and <max> is the limit (core/batch with the 0x02 (2) flag).WRONG_PRMS_LIMIT: the limit on the number of message parameters is negative or exceeds the maximum (core/set_prms_limit). |
| 5 | Error performing request. | EVENTS_ARE_DISABLED: the event subsystem is disabled for the requested detector (events/get_last, events/load, unit/get_events, resource/get_driver_bindings).EVENTS_ARE_INITIALIZING: the event subsystem is still initializing (resource/get_driver_bindings).TWILIO_REQUEST_FAILED: the Twilio HTTP request failed (accounts/get_twilio_templates).PARSING_ERROR or UNKNOWN_ERROR: the file can’t be parsed (exchange/convert_file). |
| 6 | Unknown error. In many cases the response doesn’t contain the reason field. |
UNKNOWN_ERROR: the request fails for an unspecified reason (unit/create_task, unit/update_task, gis_get_route, gis_get_many_to_many_route, gis_get_one_to_many_route, gis_get_route_via_waypoints).Internal server error: an internal session, storage, or response-building operation failed (various handlers).GET_MESSAGES_UNKNOWN_ERROR: the message manager can’t return data (resource/driver_actions_list, resource/driver_actions_cleanup, resource/driver_actions_register, resource/bind_unit_driver).Large response: the response of core/batch is too large to be built.BATCH_RESPONSE_TOO_LARGE size=<size> max=<max>: the response of core/batch exceeds the limit on its size, where <size> is the size of the response in bytes and <max> is the limit (core/batch with the 0x02 (2) flag).ERROR_CREATING_RESOURCE_DUE_TO_BILLING_RULES: the resource can’t be created according to the billing restrictions (core/create_resource).Internal error (http service unavailable): the internal HTTP client service isn’t available while a third-party authorization token is verified (user/bind_auth_service).Internal error (failed to connect to remote service): a connection to the authorization provider can’t be opened (user/bind_auth_service).Internal error (bad http response <code>): the authorization provider returns an HTTP status other than 200, where <code> is that status (user/bind_auth_service).Failed to parse remote response: the response of the authorization provider isn’t valid JSON (user/bind_auth_service). |
| 7 | Access denied. The current user or token doesn’t have the required access to the target item or operation, or a billing service required by the endpoint is disabled. The methods which create or modify items also return this error while the account of the user is being moved to another data center, even if the user has all the required access rights. In this case, repeat the request once the move is completed. In most cases the response doesn’t contain the reason field. |
USER_DISABLED: the user is disabled (token/login).Access denied: a billing service required by the endpoint is disabled for the user, for example, videomonitoring for videostorage_config, or billing_by_codes for the unit/get_billing_code and codes/* methods.Unauthorized user: there is no current user in the session (chat and driver session endpoints).Other endpoint-specific reasons are documented on the respective method pages. |
| 8 | Invalid username or password. All the following reason values are returned by token/login. |
TOKEN_USER_NOT_FOUND: the user GUID in the token doesn’t match any user.INVALID_AUTH_TOKEN: the token payload can’t be parsed.INVALID_AUHT_TOKEN: the session can’t be initialized from the token. OPERATE_AS_USER_NOT_FOUND: <login>: the user specified in the operateAs parameter doesn’t exist.OPERATE_AS_USER_NO_ACCESS: <login>: the token owner has no OPERATE_AS access right to the specified user, or the user isn’t in the list of items available for the token.SOME_LOGIN_PROBLEMS: the session for the specified user can’t be created for an unspecified reason. |
| 9 | Authorization server unavailable. In many cases the response doesn’t contain the reason field. |
INTERNAL_ERROR: the top account of the current user can’t be found (user/share_billing_code, user/unshare_billing_code). |
| 10 | Too many requests of the same kind are processed at the same time, for example, 5 simultaneous recalculations. In core/batch, if the flags parameter includes the 0x01 (1) flag, the requests which follow the first error aren’t run. The same happens if the batch exceeds the time limit set on the server. Each of the remaining requests returns error 10 without the reason field. |
ERROR: simultaneous recalculations limit (<limit> simultaneuos recalculations) reached, where <limit> is the allowed number of recalculations (admin/recalculate_history). |
| 11 | Password reset error. In some cases the response doesn’t contain the reason field. All the following reason values are returned by core/reset_password_request. |
USER_OR_EMAIL_NOT_CORRECT: the user doesn’t exist, or the email address doesn’t match the one specified for the user.PASSWORD_IMMUTABLE: the password of the user can’t be changed.REQUEST_TOO_OFTEN: less than a minute passed since the previous password reset request. |
| 12 | Agro subsystem not loaded. | |
| 14 | A billing service required by the method isn’t available. | Video service is not available: the video service isn’t enabled for the account of the user or for its parent accounts (user/get_video_units). |
| 1001 | No messages for the selected interval. | |
| 1002 | The item can’t be created because an item with the same name already exists, because of the billing restrictions, or because the specified identifier is already in use. | NAME_ALREADY_EXISTS: an item with the same name already exists (core/create_resource, core/create_user).ERROR_CREATING_RESOURCE_DUE_TO_BILLING_RULES: the resource can’t be created because of the billing restrictions (core/create_resource).ERROR_CREATING_USER_DUE_TO_BILLING_RULES: the user can’t be created because of the billing restrictions (core/create_user).User already exists: the third-party authorization identifier is already bound to another user (user/bind_auth_service). |
| 1003 | A limit is reached, or the request can’t be processed at the moment. | LIMIT <rule_name>: the specified limit is reached, for example, LIMIT api_concurrent or LIMIT invalid_logins (avl_evts, core/login, core/use_auth_hash, core/check_unique, token/login, token/update, report/apply_report_result).LOCKER_ERROR: an internal error of the service which counts the limits. Returned by the same methods, as well as by user/update_password and user/verify_code.LAYERS_MAX_COUNT: the limit of 50 message layers is reached (render/create_messages_layer).NO_SESSION: a new session can’t be created (core/login, core/duplicate).Accept-Encoding is not gzip: the request doesn’t use gzip encoding (messages/load_interval). |
| 1004 | A message limit is reached. | LIMIT msgs_count: the limit of loaded messages is reached (messages/load_interval, render/create_messages_layer, report/apply_report_result).LIMIT msgs_activity: the limit of messages loaded within a period of time is reached (report/apply_report_result).EXCEEDS_LIMIT_MSGS_COUNT: the number of messages requested in the loadCount parameter exceeds the maximum allowed for the method (messages/get_task_messages). |
| 1005 | The report execution time exceeded the limit (report/exec_report), or the hardware configuration is wrong (unit/update_hw_params). |
| 1006 | A limit related to the password or to the two-factor authorization code is reached. | LIMIT <rule_name> for password update: too many attempts to update the password (user/update_password).LIMIT <rule_name> for verify code: too many attempts to enter the two-factor authorization code (user/verify_code). |
| 1011 | Your IP has changed, or the session has expired. |
Item transfer error codes
The following codes are returned when an item is moved to another resource or account. Codes 2001..2013 are returned by account/change_account.
| 2001 | Wrong item or target_resource. |
| 2002 | The target_resource isn’t an account. |
| 2003 | Wrong target plugin. |
| 2004 | The target account is blocked. |
| 2005 | Invalid creator of the target_resource. |
| 2006 | The target_creator doesn’t have access to the item. |
| 2007 | Wrong source resource. |
| 2008 | The item is already in the target_resource. |
| 2009 | The target_resource is owned by a different top user. |
| 2010 | The target account doesn’t have enough resource quota to accept the item. |
| 2011 | Wrong item plugin. |
| 2012 | Error changing the billing account item to target_resource. |
| 2013 | Error changing the item creator. |
Other item and sensor errors
| 2014 | The selected user is the creator of some system objects, so this user can’t be assigned to a new account (core/create_resource). |
| 2015 | The sensor can’t be deleted because it’s used in another sensor (as a validation sensor) or in advanced unit properties (motion state sensor, sensors colors, monitoring sensor) (unit/update_sensor). |
