Registered events
When you request messages of the Registered events type, you can see a table with the events added to the unit history manually or automatically.
The table can contain the following columns:
Column Description
Time The time the event was saved by the system (in the case of automatic registration) or the time specified by the user (in the case of manual registration).
Type The type of event: custom, unit status, and so on.
Event text The description of the event. If the event is registered by means of a notification, the description is taken from its text. In the case of manual registration, custom events and unit statuses are displayed with the descriptions specified by the user.
You can filter the events by text.
If there is data on the location where the event has occurred, this place is indicated on the map with the marker  when you click on the event row.
See more about working with the table and deleting messages here.
