Transferring Unit Properties
You can copy most of the properties from one unit to another or save them to a WLP file using the import and export tool. The exceptions are:
  • user access rights;
  • unit group membership;
  • information about the creator and the account.
To export unit properties, select the Export to WLP item in the user menu and select Unit in the Export from drop-down list. See a detailed guide here.
To add the properties of one unit to another using a WLP file, select the Import from WLP item in the user menu and follow the guide.
Exportable properties
Below are the unit properties you can export.
PropertyDescription
General properties
The device type, name, phone number(s), unique ID, access password (the General tab).
Units with the same ID and units with the same phone numbers within the same device type cannot exist in the system. Such fields are cleared during import. You can edit them later.
Icon
The icon of the unit and the state of the Rotate icon option.
To export an icon uploaded by the user, you should have the View object and its basic properties access right to the unit the icon of which you want to export.
Device configuration
The parameters of the device configuration. They can be available for some types of devices on the General tab after clicking on the icon .
CountersThe current values of counters and the state of the options for calculating them (the General tab).
Report propertiesThe parameters from the Additional settings and Speeding sections of the Advanced tab.
Advanced propertiesThe colour parameters and the message validity filtering parameters from the Advanced tab.
SensorsThe contents of the Sensors tab.
Custom fieldsThe contents of the Custom fields tab.
Administrative fieldsNot applicable in the system.
CommandsThe contents of the Commands tab.
Trip detector
The contents of the Trip detector tab.
See also
