Services
This tab displays all the services available for the selected billing plan.
To find the service by its name, start typing in the dynamic search field.
The “Services” tab filters
The services can be arranged into groups using the following filters: All, General, Sites, Apps, Maps.
All
The group contains all the available services. Here you can enable or disable the service, configure the Limit and cost setting and select the reset period. See the services description for more details on each service.
General
The group includes general Wialon Lite functionality, such as Units, Commands, Geofences and others. Here you can enable or disable the service, configure the Limit and cost setting and select the reset period.
Sites
The services in this group enable access to different sites. You can add a URL for your own white label site with the Wialon Lite functionality. To do this, contact your Partner Success Manager.
In the Sites group, you can enable or disable the service.
Apps
The group includes services that enable your custom applications.
Maps
The group contains all the available map services. Top account users can add maps on the Map management tab. In this group, you can enable or disable the service.
Service settings
Depending on the selected filter, the list of services can consist of the following columns:
Column Description
Name The name of the service. See the full list of services and their description here.
Status The state of the service. Click on the button to disable or enable the service.
By default, the deactivation of a service in a billing plan leads to its automatic deactivation in the account to which this plan is assigned. However, if the state of the service is additionally changed in the properties of a separate account, then it is given priority.
An account user does not have access to services that are disabled in a parent account.
Limit and cost In this column, you can specify the values of the service quantity and cost. For example, if you specify number 100 for the Units: Access service, this means that no more than 100 units can be created in the accounts to which this billing plan is assigned. You can indicate the limit and cost for the billing plan in the same way as for the account.
Reset Here you can select how often the specified service limit should be reset: hourly, daily, weekly, or every calendar month (monthly). For example, if you specify 10 SMS messages per day, then the users of the accounts to which the billing plan is assigned cannot send more than 10 messages a day.
Limit This column shows the limit on the service quantity applied to the top account. The limit is set automatically based on the total number of units in all the accounts of the service.
You can sort the services by their name and status by clicking on the column heading.
The icon exclamation sign icon at the bottom of the window means that there is an issue in a higher level account. If the service availability is limited in the higher or top account, the service will not function correctly in the subordinate account. Hover over the icon to see the tooltip.
