Statistics
The Statistics table consists of selected columns and their values.
The table gives information on the report as a whole, for example, on the beginning and end of the report interval, the number of messages, the name of the unit, the time zone, the time of report execution, and other statistics, depending on the selected report template type.
To add the statistics table to a report template, click on the Statistics button on the Report Contents tab of its properties.
In the dialog window of the Statistics table properties, select the columns that should be included in the table. To find the required ones, use the dynamic search located in the upper right corner. Search is carried out both by the name of the column (to the left) and by the type to which it belongs (to the right).
To change the name of the column, click on it with the left mouse button and make the changes. To cancel changes, click on the Default icon (). The icon is inactive if the name has not been changed.
You can also change the sequence of columns. To do this, drag the icon  located to the left of the required column name.
The statistics table is added to the list of contents of the report template. It always goes first and cannot be moved.
Below are the available columns that can be added to the statistics table for the reports of the Unit type.
Stops
ColumnDescription
Stops countThe number of stops for the reporting period.
Parkings
ColumnDescription
Parking timeThe total duration of parkings for the reporting period. Parking is determined by the trip detector. If it is disabled, the number of parkings is counted as zero.
Parkings countThe number of parkings for the reporting period.
Statistics
ColumnDescription
ReportThe name of the report template.
UnitThe name of the unit.
Report execution timeThe time of report generation when a user executed the report online or it was generated automatically as a job or notification.
Interval beginningThe beginning of the reporting interval.
Interval endThe end of the reporting interval.
Time zoneThe time zone set in the user settings.
MessagesThe messages analyzed within the reporting period.
Mileage in all messagesThe mileage in all messages according to the selected mileage counter (without filtering by the trip detector).
ConsumedNot applicable in the system.
Consumed by ImpFCS/AbsFCS/InsFCS/FLS/math/ratesNot applicable in the system.
Consumed by ImpFCS/AbsFCS/InsFCS/FLS/math/rates in motion
Consumed by ImpFCS/AbsFCS/InsFCS/FLS/math/rates without motionNot applicable in the system.
Avg consumptionNot applicable in the system.
Avg consumption by ImpFCS/AbsFCS/InsFCS/FLS/math/ratesNot applicable in the system.
Initial fuel levelNot applicable in the system.
Final fuel levelNot applicable in the system.
Max fuel levelNot applicable in the system.
Min fuel levelNot applicable in the system.
When executing a report on a unit group the statistics include the following data:
  • Report;
  • Group;
  • Interval beginning;
  • Interval end;
  • Report execution time.
