Top panel
In the upper panel on the left, there is the logo of the tracking services provider, and on the right, there is the menu setting button and the username with which the user has logged in.
The main menu of the program occupies the central part of the top panel. It contains different elements depending on the settings applied and also on the modules provided.
User menu
In the right corner of the top panel, the username used to log in is displayed. If you log in as another user, his or her username is indicated in brackets next to yours.
Clicking on the username opens the user menu with the items listed below.
Menu item Description
User settings Opens user settings for viewing and/or editing.
Session management Opens the Session management window.
Locator Allows you to create temporary links so that unregistered users can track units without having an account (see more).
Import/Export Enables to transfer the settings of units, users, resources’ contents (refer to Import and export).
Help Help request. This is a link to third-party Internet resource containing documentation. By default, it is disabled. To activate the option, contact technical support and provide corresponding URL addresses.
Logout Click here to log out of the system (session termination).
Information messages and warnings
In the top panel under the username, information messages from the service manager can appear.
Below the username, you can also see attention messages about blocking your account. These messages are not displayed for the users of top accounts.
