System requirements and optimization
Consider these requirements to get the most from the platform.
Web browser
Supported browsers are:
  • Google Chrome
  • Mozilla Firefox
  • Opera
  • Microsoft Edge
Update your browser to the latest stable version to work better with the platform. In other versions or browsers, the system may function incorrectly.
Computer capability
Computer capability affects browser operation. The key points of high performance are CPU (central processor) and RAM capacity. Multi-core processors do not affect browser operation in most cases. The exception is Google Chrome that can use more than one core in its operation.
Considering the information mentioned above, the minimum requirements are:
  • CPU at 1,6 GHz clock rate;
  • 512 MB of RAM.
and recommended requirements:
  • CPU at 2,4 GHz clock rate (a processor with two and more cores is recommended if Google Chrome is used);
  • 2 GB of RAM.
Monitor size and screen resolution should also be taken into account. The bigger the monitor is, the more data is queried from the server and processed by the CPU. For this reason, the program may work perfectly on a 17-inch screen but start running slow on the 22-inch one. The solution for big monitors is not to use a browser in a full-screen mode. This issue is especially actual at the low speed of Internet connection.
Antivirus software as well as gathering actual data from units can slow down computer performance. If the platform is running slower, you can add it to the list of exceptions or simply disable antivirus monitoring during the Wialon Lite session. You can also create a rule which allows Wialon Lite to have any network activity.
Internet connection
A 1 Mbit Internet connection channel is enough for the normal operation of the platform on one computer. If more than one operator will work simultaneously, do the speed test, and choose the most appropriate speed.
Optimization measures
Here are some tips, which will help you to improve Wialon Lite performance in cases when more than a hundred units are connected.
Web browser
Web browser plays a very important role. Use only the browsers specified in the list of supported browsers. Google Chrome is the most efficient one. It is followed by Mozilla Firefox and Opera. The slowest, according to our tests, is Internet Explorer.
The performance of the monitoring system strongly depends on the event system of the browser in which Wialon Lite is started. Each browser has its individual event model. As the tracking system is rather dynamic and tracks change with up to a 2-second delay, some browsers (for instance, Internet Explorer) cannot process such a large quantity of events. The solution here is to use a more powerful computer.
Graphics & tooltips
The display of graphic elements on the map and in the lists is resource-consuming. If you notice that your browser is getting slower, try to disable the display of the following elements: units, geofences, places, tracks, as well as names, direction arrows, and ‘tails’ for units (these elements can be disabled with the help of the three corresponding buttons in the Visible layers menu). Limit the number of units displayed on the Monitoring tab. Limit the number of other objects displayed on other tabs that are frequently used (apply the filter to do that). Enable only those elements that are required for your work at the moment.
The optimal settings for unit display can be adjusted in the Unit visualization on map section of the General settings tab. Besides, if the speed of the Internet connection allows it and there are no restrictions on traffic, geofences can be drawn not in the browser, but on the server. This option is enabled in the user settings on the General settings tab in the Other items on map section.
A tooltip and additional information about the unit should also be taken care of. In the Show additional information about the unit section of the User settings dialog, it is recommended to turn off the parameters that are not used (if necessary, switch off all the parameters). If there are a lot of geofences or geofences composed of multiple points and the Presence in geofences option is enabled, your browser can become overloaded. In such a case, make sure this option is disabled.
If the Internet connection is slow or you need to save the traffic, disable geofence rendering on the server. Besides, when you use reports with a map, messages, and tracks clear your request when it is no longer useful.
Pay attention that for the charts to be displayed, the browser you use has to support the WebGL component. If the browser or the operating system cannot support it, enable the Render charts on server option in the User settings dialog (limited functionality will be available).
Queries to server
When Wialon Lite starts, not all the data is loaded at once. It is made to speed up the loading and operation. That is why some actions that are performed for the first time may take more time than in the future. Resource-consuming reports (such as reports on groups or reports with grouping and detalization) should be avoided. Enclosed rows of detalization stay hidden until you expand them, and if there are a hundred or more enclosed rows, the browser may freeze.
