Using Passengers
Apart from the Passenger tab, you can see passengers on the map on other tabs. You can also use passengers in reports and notifications.
Passengers in reports
You can use passengers in the following reports:
Report typeUsage method
Report on units and unit groups
You can add the Passengers count column to the Trips table. The column allows you to see the number of passengers assigned to the unit for each trip within the reporting interval.
Report on passengers and passenger groups
You can add the Assignments table to the reports on passengers and passenger groups. The table allows you to see detailed information about passenger assignment and separation.
Passengers in notifications
To monitor passengers getting on and off vehicles in real time, you can create a notification of the Passenger activity type. Using a notification of the Passenger alarm type, you can receive alarm messages if any of the passengers doesn’t get off the vehicle in time.
See also
