Trash
The units deleted from the system are placed in trash. It means that they can be restored. A required term of storage should be chosen from the dropdown list in the header of a trash block (30 days by default).
On the list, you can see unit’s name, type, and date and time of deletion. Unit types are the following:
  • avl_unit — unit;
  • storage_user — user;
  • avl_resource — resource;
  • avl_unit_group — unit group;
  • avl_retranslator — retranslator;
  • avl_route — route.
Any unit from the list can be restored or deleted from the system completely. To restore/delete multiple units at once, select them with a mouse click and then click Restore all or Delete all in the header.
Deleted units are always restored into the root account wialon. If needed, you can transfer them later to the accounts that stay lower in the hierarchy. Moreover, you should take into consideration that restoring units is, in fact, their re-creation, which means that it requires free slots.
Download PDF file
Download Word document
See also
