Sent Commands
When you request this type of messages, you can see a table with the commands that have been sent to the unit.
The table can contain the following columns:
Column | Description |
Time | The date and time of sending the command from the server. |
User | The name of the user who has sent the command. If you don't have the View object and its basic properties access right to this user, a dash is displayed instead of the name. |
Command name | The name specified when creating the command. |
Command type | The type selected when creating the command. |
Parameters | The command parameters specified when creating or sending the command (if applicable). You can filter the commands by these parameters. |
Execution time | The date and time of executing the command. If the command couldn't be executed due to the billing plan limitations, a dash is displayed. This may happen, for example, if the SMS channel is used for sending the command when the limit of available SMS messages has already been reached. |
Channel | The data transmission method used to send the command: TCP, UDP, Virtual или SMS. See more. |
See more about working with the table and deleting messages here.
