Units
A unit (a monitoring unit) is a tracked vehicle, machinery (including stationary), person, or animal.
You can work with units in the monitoring system (the Units tab) and in the management system (the Units section).
The table of the Units section contains all the created units which you can track in the monitoring system. It also shows deactivated units which are unavailable to users in the monitoring system. To quickly find units, use the dynamic filter.
In this section, you can perform the following actions with units: create, deactivate, transfer them from one account to another, etc.
Selecting columns
To select columns with additional information about units, click on the icon  in the table header. In the menu, the following columns are available:
ColumnDescription
#The sequence number of the unit in the table.
SelectThe selection of the unit in the table.
IconThe unit icon selected on the same-name tab of the unit properties.
NameThe unit name specified in the general properties of the unit.
CreatorThe user on whose behalf the unit was created.
AccountThe account to which the unit belongs.
Device typeThe device type specified in the general properties of the unit.
DeactivationThe date and time of the unit deactivation in the system. They are displayed only in the lines of deactivated units.
CreatedThe date and time of the unit creation in the system.
UIDThe identification number of the device in the system, which is specified in the general properties of the unit.
PhoneThe phone number of the SIM card installed on the device. Specified in the general properties of the unit.
Last messageThe information about the time of receiving the last message from the unit.
GroupsThe groups to which the unit was added.
Custom fieldsThe custom fields created on the same-name tab of the unit properties.
Log
The icon  which allows you to open the log of the unit.
Actions with units
You can perform standard actions with units:
  • create (the Create unit button);
  • copy;
  • view/edit properties;
  • delete.
In addition, the following actions are available:
ActionDescription
Create a unit from a WLP file
To do this, click on the Create from WLP button, upload the file, select the required parameters, and click Next.
For details, see the Creating a unit from a WLP file section.
Deactivate/Activate units
To do this, click on the Unit deactivation button, move units from the left list to the right one, and click OK.
To activate units, move them from the right list to the left one and save the changes.
The action is available only for top accounts and accounts with dealer rights for which the billing plan with charges for each unit is used.
For details, see the Unit deactivation page.
Transfer units to another account
To do this, click on the icon  (Switch account), move units from the left list to the right one, select the account in the drop-down list, and click OK.
For details, see the Transferring units from one account to another page.
