Sensor Types
When creating a sensor, you should select its type in accordance with the principle of its operation and the equipment used.
The types of sensors provided in the Wialon system are divided into six groups:
  • mileage,
  • digital,
  • gauges,
  • engine,
  • fuel,
  • other.
The sensors from each group are described below.
Mileage
This group includes sensors which are used to determine the travelled distance.
Sensor typeUnits of measurementDescription
Mileage sensorkm (kilometers), mi (miles)
The sensor which shows the distance travelled by the unit. You can use it in the trip detector to detect trips and parkings.
Relative odometerkm (kilometers), mi (miles)
The sensor which shows the distance travelled by the unit since the last message was received from it. You can use it in the trip detector to detect trips and parkings.
Digital
This group consists of sensors which can have only two states. For example, on/off, activated/deactivated, and so on.
Engine ignition sensor
On/Off
or any
The sensor which shows whether the ignition is on or off. You can use it in the trip detector to detect trips and parkings and in mileage and engine hours counters. In addition, you can use the engine ignition sensor to detect fuel thefts at idle. To do this, you should specify the fuel consumption rate at idle in the Consumption, liters per hour field.
Alarm triggernone
The sensor a non-zero value of which allows marking a message as an alarm one (SOS). The messages registered in the system before the creation of the sensor are not marked as alarm ones.
Private mode
On/Off
or any
The sensor which is used to determine the trip type (Business, Private).
Real-time motion sensorOn/Off
The sensor which determines the movement state of units in real time. The movement state determined by the sensor is shown on the map and in the work area on the Monitoring tab. To do this, the Replace unit icons with motion state signs option should be enabled in the user settings as well as the Motion state option on the Monitoring tab. The sensor readings can be based on the values of speed, ignition, engine revolutions, etc. As for other sensor types, you can specify an expression parameter and configure validation.
Custom digital sensor
On/Off
or any
The custom sensor which has two states: on/off, activated/deactivated, etc.
Gauges
This group contains sensors which are used to measure values such as voltage, weight, acceleration, temperature.
Voltage sensorV (volts)
The sensor which shows the voltage value. For example, this value can be used to determine temperature or the ignition state.
Weight sensort (tons), pounds
The sensor which is used to determine the weight of transported goods.
Accelerometerg
The sensor which is used to determine acceleration along the X, Y, Z axes, which allows detecting a collision, that is, a road traffic accident.
Temperature sensor°C (degrees Celsius), °F (degrees Fahrenheit)
The sensor which shows the temperature value or any other parameter. You can use the temperature sensor to analyze received values. See a configuration example.
Temperature coefficientnone
The coefficient which is used to calculate the fuel level at different temperatures in the tank more precisely. See a configuration example.
Engine
This group includes sensors which are used to measure values associated with the engine operation.
Engine revolution sensorrpm (rounds per minute)
The sensor which shows the frequency of engine revolutions.
Engine efficiency sensoranyThe sensor which is used to determine the movement coefficient under load, which is used to calculate the fuel consumption. The sensor can function as a reduction coefficient if its values are from 0 to 1. You can specify any unit of measurement for this sensor.
Absolute engine hoursh (hours)
The sensor which shows the total number of engine hours.
Relative engine hoursh (hours)
The sensor which shows the number of engine hours, taking into account the work intensity coefficient. See a configuration example
Using relative and absolute engine hours, you can also detect fuel thefts at idle. To do this, you should specify the fuel consumption rate at idle in the Consumption, l/h field.
Fuel
This group consists of sensors which can be used to determine the amount of consumed fuel and the fuel level in the tank.
Impulse fuel consumption sensorl (liters), gal (gallons)
The sensor which shows the accumulated value of impulses. To convert the received value into the amount of consumed fuel, you should configure the calculation table and activate the Calculate fuel consumption by sensor option. For sensors of this type, the calculation table is applied to the difference between two messages in a row. If the device sends not the accumulated value of impulses but the number of impulses between messages, you should use the instant fuel consumption sensor.
Absolute fuel consumption sensorl (liters), gal (gallons)
The sensor which shows the fuel consumption for the entire period of the vehicle operation. To get data on the fuel consumption for a specific period, you should take the sensor values at the end of the selected period and deduct the sensor values at the beginning of the period. In the sensor properties, you should enable the Calculate fuel consumption by sensor option.
Instant fuel consumption sensorl (liters), gal (gallons)
The sensor which shows the amount of consumed fuel since the previous measure (message). In the sensor properties, you should enable the Calculate fuel consumption by sensor option.
Fuel level sensor l (liters), gal (gallons)
The sensor which determines the fuel level in the tank. In the sensor properties, you should enable the Calculate fuel consumption by sensoroption. See a configuration example
Impulse fuel level sensorl (liters), gal (gallons)
The sensor which is designed to calculate the amount of fuel in the tank. When calculating the amount, the difference in the values of the impulses from two messages in a row is divided by the time difference between them.
Other
This group includes a custom sensor and sensors which are used to control passengers, drivers, and trailers.
Counter sensorany
The sensor which allows determining the intensity of passenger traffic or the number of certain actions (for example, opening and closing the door). There are several types of such sensors:
  • instant (shows the difference of values between two messages in a row);
  • differential (shows the total number);
  • differential with overflow (2 bytes);
  • switch from ON to OFF (counts the number of deactivations);
  • switch from OFF to ON (counts the number of activations).
You can specify any unit of measurement for this counter.
Custom sensorany
The sensor which can be configured to measure any value. You can specify any unit of measurement for this sensor.
Driver assignmentnone
The sensor which can be used to detect the assignment of the driver to the unit.
Trailer assignmentnone
The sensor which can be used to detect the assignment of the trailer to the unit.
Passenger sensornone
The sensor which can be used to detect when passengers are picked up or set down.
