Check Points
Route points refer to check points indicated when creating a route. The table can include the columns described below.
| Column | Description |
| Point name | The name which is given to this checkpoint while creating it. |
| Real arrival | The time when the unit entered the checkpoint. |
| Scheduled arrival | The time when the unit was supposed to enter the checkpoint according to the schedule. |
| Initial location | The location at the time of entry. |
| Real departure | The time when the unit left the checkpoint. |
| Scheduled departure | The time when the unit was supposed to leave the checkpoint according to the schedule. |
| Final location | The location at the time of departure. |
| Result | Visited (both entrance and exit were detected), Entrance only, Exit only, Skipped. |
| Route | The name of the route to which this checkpoint belongs. |
| Schedule | The name of the schedule. |
| Ride | The name of the ride. |
| Arrival time deviation | A positive value if delayed, negative value if in a hurry in regards to the arrival time set in the point properties. |
| Departure time deviation | A positive value if delayed, negative value if in a hurry in regards to the departure time set in the point properties. |
| Presence duration | The time spent at the checkpoint. |
| Presence mileage | The mileage at the checkpoint. |
| Section duration | The time spent to travel from the previous checkpoint to the current one. |
| Section mileage | The mileage from the previous checkpoint. |
| Count | The number of points. |
| Driver | The name of the driver (if available). |
| Trailer | The name of the trailer (if it was assigned). |
| Notes | An empty column for your custom comments. |
