Fuel Drains
This report table allows you to find out when and where fuel drains occurred. They are detected during stops and while the unit is parked, as well as while it is moving, provided that the Detect fuel drains in motion option is enabled. The parameters for this report are set in the properties of fuel level sensors.
The columns available in the table are described below.
ColumnDescription
BeginningThe date and time when the drain began.
Initial locationThe unit's location at the time of the beginning of drain.
TimeThe moment of the most significant drop in the fuel level.
Final locationThe location of the unit at the time of the fuel drain (the Time column).
Initial fuel levelThe fuel level before the drain.
Initial speedThe speed at the time of the beginning of drain.
DrainedThe potentially drained fuel volume.
Final fuel levelThe fuel level after the drain.
Final speedThe speed of movement at the time of the fuel drain (the Time column).
Sensor nameThe sensor that detected fuel drain.
DriverThe name of the driver (if identified).
TrailerThe name of the trailer (if it was assigned).
CountThe number of drains.
CounterThe counter sensor value.
MileageThe mileage sensor value at the moment of drain. If the mileage parameter was not saved throughout the reported period, the mileage is counted from 0.
Avg value of custom sensor
The average value of the custom sensor registered during the drain.
This and the following columns of custom sensor values show 0 if the value is invalid. For example, if the value is not within the bounds set in the calculation table.
Min value of custom sensorThe minimum value of the custom sensor registered during the drain.
Max value of custom sensorThe maximum value of the custom sensor registered during the drain.
Initial value of custom sensorThe value of the custom sensor registered before the drain.
Final value of custom sensorThe value of the custom sensor registered after the drain.
ImageThe images received from the unit. Viewing images in reports and the functions available while doing this are described here.
The table may show rows with fillings and drains marked as false. To do this, the Show false events option must be enabled in the report settings.
Read about how to avoid detection of false drains in the expert article How to get rid of false fuel drains.
The interval filtration by geofences/units, driver, trailer, and drain volume can be additionally applied to this table.
Special markers can be shown on the map in the places of drains.
Information on fuel fillings can be found here.
Questions and answers
There has been a fuel drain, but it is not shown in the report. Why?
Possible explanations and actions:
1. Test drain right before fuel filling.
If you made a defueling for test purposes and then refueled the vehicle right away, the system may regard this as an outlier of data. In real situation, when a drain is not followed by immediate refueling, such drain will be detected.
2. Drain during a prolonged shutdown of the device.
A drain can be detected only if the Calculate fuel consumption by time option is off (see the properties of the fuel level sensor) and if there is a trip after switching on the device again.
3. High filtering level of FLS.
Decrease the filtering level of FLS in its properties (recommended are values up to 15) or set the Calculate drain volume by raw data option.
4. High value of minimum drain.
Decrease the value of the minimum drain volume in the properties of the fuel level sensor.
Reports show incorrect mileage. What should I do?
1. Outliers of data.
To detect such outliers, build a track of unit movement for the appropriate period. Outliers of data will be seen on the track as dashed lines.
Ways to overcome outliers:
  • Enable filtering of unit positional information in messages (on the Advanced tab of unit properties). This will not affect old messages but applied to new ones.
  • To correct data in reports, change settings of trip detection, in particular, reduce Maximum interval between messages and increase Minimum satellites.
2. Incorrect settings or operation of the mileage counter.
  • Check the mileage counter settings on the General tab of unit properties.
