Show Additional Information About Units
In this section, you can configure additional information about the unit. The items selected in the Tooltip column determine the contents of the unit tooltip, while those selected in the Work list column determine the contents of extended information about the unit in the work list.
To select or cancel the selection of all the items in a group, click on any item in the required column while holding down the Ctrl key.
You can change the order of the items to the left of which the icon  is shown. To do this, drag the icon up or down.
Additional information about the unit can include the following data:
Item Description
Last message time The time when the last message was received from the unit.
Icon The enlarged icon of the unit. If this option is enabled, an enlarged unit icon is shown in all the tooltips and extended information.
Location The last known address of the unit.
Presence in geofences If, according to the last message, the unit was within a geofence, then this geofence is shown in the additional information in the colour selected in its properties. This item also affects the count of units in geofences.
Speed The speed value from the last unit message.
Altitude The altitude from the last message, if the device sends such data.
Counters The values of mileage and engine hours counters.
Satellites The number of satellites with which the device established connection, according to the last message.
Coordinates The geographic coordinates of the unit from the last message (in decimal degrees). When you click on the coordinates, it is possible to go to the map of a third-party source. See more.
Sensor values The names and values of sensors. If a calculation table is configured for a sensor, its values are converted. If filtering is configured for a fuel level sensor, its values are shown before they are filtered.
When displaying sensor values, the system takes into account the Last message only option from the sensor properties. You can read more about it here.
If the numerical value of the parameter sent by the sensor exceeds 53 bits (9,007,199,254,740,991), the accuracy of displaying this parameter in the interface and reports is reduced starting from the lower bits. However, such values can be processed, for example, by bitwise control or used for sensors with bitwise control.
Connectivity settings The device type, unique ID and phone number(s) specified in the unit properties. This information is available only to the users with the Edit connectivity settings access right to the unit.
Parameters The last known parameter values. You can see only the parameters sent by the unit in the last 24 hours. The parameter name and value are shown in the same way as in the message, without conversion to any units of measurement.
Custom fields The custom fields from the unit properties. Depending on access rights, you can see general and/or administrative custom fields.
Profile The profile properties of the unit.
Maintenance state The information about the vehicle maintenance based on the intervals created in the unit properties.
Drivers The name, photo and phone number of the driver assigned to the unit, as well as the information about the driver activity. Several drivers may be shown.
Trailers The name and photo of the trailer that assigned to the unit. Several trailers may be shown.
Multicolour sensors in unit tooltips For this feature, you can select the following options in the drop-down list:
  • Disabled. The information about sensors is shown in black in the unit tooltips.
  • Apply to sensor name and value. The name and value of the sensor are shown in the unit tooltip in accordance with the colour scheme configured in the sensor properties;
  • Apply to sensor value only. The value of the sensor is shown in the unit tooltip in accordance with the colour scheme configured in the sensor properties;
The values of the mileage and engine hours counters as well as information about drivers and trailers are updated once a minute. A check for unit presence in geofences is carried out every two minutes. The rest of the information is refreshed instantly.
