Sent Commands
This kind of report lists all the commands that were sent to a unit over the reporting period. The possible columns are described below.
Column Description
Sending time The time when the command was sent to the unit.
User The name of the user who sent the command (hidden if you do not have access rights to the user).
Command name The name of the command as it is written in the unit properties.
Command type The type of the command (see the list).
Parameter The additional parameter in the command (some commands do not have such parameters).
Execution time The time when the command was executed.
Channel The type of connection used to execute the command (TCP, UDP, Virtual, SMS).
Count The number of sent commands.
Notes An empty column for your custom comments.
This is the list of successfully executed commands. To view all the commands sent to the unit regardless of their execution, go to the Messages tab.
