Markers
In this section, you can select the markers that should be displayed on the map, enable their numbering, and configure filtering for the markers shown on the map and in charts.
The table below shows all the available markers.
MarkerNameDescription
Parking marker
Marks a location where, according to the trip detector, a parking took place.
Stop marker
Marks a location where, according to the trip detector, a stop took place.
Filling marker
Marks a location where, according to the sensor data, a fuel filling took place. Fuel fillings marked as false in the table or on the chart are marked with a marker . To see markers of false fillings in reports and on the map, the Show false events option must be enabled in the report settings.
Drain marker
Marks a location where, according to the sensor data, a fuel drain took place. Drains marked as false in the table or on the chart are marked with a marker . To see the markers of false drains in reports and on the map, the Show false events option must be enabled in the report settings.
Event marker
Marks locations where events were automatically registered by means of notifications. The events registered manually, including fuel fillings, are also shown by such markers if a location (and preferably a description) is indicated during event registration.
Violation marker
If you select event markers, then both event and violation markers are displayed because a violation is a special case of an event.
Speeding marker
Marks a location where speed limits indicated in the unit properties were violated.
Image marker
Marks a location where pictures were received from the unit.
Video marker
Marks a location where videos were received from the unit. To open the video, click on the View button below the address.
Initial position markerMarks the track start. If the Trip tracks option is enabled, this marker indicates the start point of each trip within the track.
Final position markerMarks the track end. If the Trip tracks option is enabled, this marker indicates the end point of each trip within the track.
You can configure filtering (icon ) for filling, drain, stop, parking, speeding, and event markers. The filtering parameters configured in this section are applied to the markers on the map and in charts.
If necessary, you can enable marker numbering.
Markers on the map
The selected markers are displayed on the map after executing the report. To see all the available markers, zoom in.
If there are no GPS coordinates in the messages received during an interval, then the marker of this interval is not shown on the map. For example, the marker of a parking interval is not shown on the map if no messages with coordinates were received while the unit was parked.
Tooltip
When you point to a marker, its tooltip displays additional information about what happened:
Marker typeInformation
Stop, parkingStart and end time, duration, location.
Event, violation
Time, event text, location.
Fuel filling, fuel drain
Time, fuel volume, the name of the sensor according to which the fuel filling or drain was detected, location.
If several fuel level sensors are configured for a unit, a separate filling or drain marker corresponds to each of them. Such a marker shows the sequence number of the sensor among the other fuel level sensors on the Sensors tab of the unit properties.
SpeedingStart time (the time of receiving the first message with a speed value exceeding the allowed one) and end time, duration, location, speed limitation as specified in the unit properties, the value by which the speed was exceeded.
Image, video, initial position, final positionTime, location.
If markers are used in a report on a unit group, their tooltips also contain a unit name.
Marker grouping
Markers, as well as geofences, can be grouped in case they overlap each other. To enable grouping, activate the Group icons option in the report template. If there are 1000 or more markers, their grouping is enabled automatically. The group icon shows the number of grouped elements. In the icon tooltip, you can see detailed information about the events.
Marker numbering
You can enable the Marker numbering option in a report template. In this case, each marker has its sequence number which is indicated below the marker in red color. Numbers are assigned chronologically, and each marker type has its own enumeration.
Panoramic images
The panoramic images of the territory can be displayed when clicking on the markers of parkings and stops. For this, maps with panoramas (for instance, Yandex Panorama or Google Street View) should be selected in the user settings. If there are pictures of the territory with the coordinates of the marker, when pointed at it, the cursor changes from arrow to hand. Click on the marker to open a panorama snapshot in the window of the Address tool. Double-click on another such marker to update the information.
