Fleetrun
Hecterra
NimBus
Other apps
Wialon for Android/iOS
Logistics
Wialon Local
Wialon Hosting
WiaTag
Configurator
LeaseControl
en
Contents
Export to WLP
  • export
This function allows you to copy unit properties, resource contents, and user settings to another object of the corresponding type or to a WLP file.
Export to a file
To export data to a new file, follow the steps below.
  1. In the user menu, select the Import/Export item and click Export to WLP.
  2. In the Export from drop-down list, select the required object type: unit, resource, or user.
    You can also export unit properties to a WLP file from the window of unit properties (the Export to file button).
  3. In the Export to line, select File.
  4. In the Source objects section, select the object the data from which you want to save to a file. To select several objects, use Ctrl or Shift (for a range of objects).
  5. In the Export options section, select the properties, settings, or objects you want to save. To select all the objects, hold down Ctrl and click on any item.
    If you export the contents of several objects at once, you cannot select specific settings, commands, sensors, custom fields, etc. from nested lists.
  6. Change the file name, if necessary. If you select only one object, its name is used by default. If you select several objects, the name corresponds to their type: Units, Resources, or Users.
  7. Complete the export.
As a result, the data is saved to a WLP file (if you select one source object) or to several files (if you select several objects).
Export to an object
To export data to an object, follow the steps below.
  1. Follow steps 12 from the Export to a file guide.
  2. In the Export to line, select Object.
  3. In the Source objects section, select the object the data of which you want to copy. You can select only one object.
  4. In the Export options section, select the properties, settings, or objects you want to save. To select all the objects, hold down Ctrl and click on any item.
  5. Click Next, after which the Import from WLP window opens.
  6. Select the import type: Replace, Merge, or Append. See more information about import types and import to system objects here.
  7. Select the object to which you want to copy the selected data. You can select several objects.
  8. Click ОК.
Thank you for your feedback!
Text with the mistake Comment
Maximum 500 characters
