Log
The log shows real-time information about the reception of unit messages, sent and executed commands as well as about user actions.
To open the log, click on the icon   in the bottom panel.
To select the types of information which should be shown in the log, click on the icon   and select the required items.
Item Description
Incoming messages Records of the messages received from the units which are in the work list of the Monitoring tab. If a message contains data on the unit location, the icon is shown at the end of the record. Click on it to see the place of sending the message on the map.
User actions Records of your actions in the monitoring system: creating, editing, deleting elements, etc.
Commands Records of the commands sent to the units and their execution.
Different colours are used to display text in the log:
  • black: for records of the received unit messages;
  • green: for records of the user actions, sent and executed commands;
  • red: for records of errors and the received SOS messages from the units.
To quickly find the required record, use the dynamic search.
You can change the log size by dragging its border or corner.
