Navigation and search panel
The navigation and search panel is located on the left side of the window. It contains a list of sections which can be shown in the area of search results. Depending on the type of account and enabled services, the following sections may be available:
To open the section, click on its name.
For most sections, two blocks are shown.
Block Description
Actions In this section, you can see a button (buttons) for creating system objects (accounts, users, units, etc.). For the Users section, the Notice board button is also available.
Search This section allows you to search for objects which already exist in the system. Read more about the search below.
To search for system objects, follow the steps below.
  1. Select the required section.
  2. In the Filter drop-down list, select a search criterion.
  3. Enter a request in the Text field.
  4. Click on the Search button or press the Enter key.
For example, if you want to find all the units created by user1, select Creator as a search criterion, enter “user1” in the Text field, and click Search.
The found objects are displayed in the area of search results on the right.
To find all the objects of a certain type (for example, all users), make sure that Name is selected as a search criterion, leave the Text field empty and click Search.
Search filter
The Filter drop-down list contains the criteria by which the search can be carried out. For most object types, the following criteria are available:
Search criterion Description
Name The name of the objects.
Creator The user on whose behalf the object was created.
Account The account to which the object belongs.
Custom fields The custom fields created in the properties of the object (the ones that are not marked as administrative fields).
Admin fields The custom fields marked as administrative in the properties of the object.
Individual search criteria are available for accounts, units, retranslators and deleted objects in the trash.
Object type Search criterion Description
Accounts Parent account The account of the user on whose behalf the account was created.
Accounts Business sphere The business sphere specified in the account properties. This criterion is available only for the top account user or users of the accounts with dealer rights.
Accounts Billing plan The billing plan selected for the account. This criterion is also available for searching for users.
Accounts Blocked accounts Searching among the blocked accounts (by name). Leave the Text field empty to see all the blocked accounts.
Units Unique ID The unique ID of the unit specified in its properties.
Units Phone number The phone number of the SIM card if it is inserted in the device (there can be two phone numbers).
Units Device type The type of the device (hardware) installed on the unit.
Units Unit group The group to which the unit (units) belong.
Units Profile fields The unit properties from the Profile tab.
Units Activated Searching among the activated units (by name). Leave the Text field empty to see all the activated units.
Units Deactivated Searching among the deactivated units (by name). Leave the Text field empty to see all the deactivated units.
Retranslators Protocol The retransmission protocol selected when creating the retranslator.
Retranslators Server The server to which the retranslator sends the unit data.
Retranslators Unit name The name of the unit the data of which is transmitted by the retranslator.
Retranslators Started Searching among the started retranslators (by name). Leave the Text field empty to see all the started retranslators.
Trash Object type The type of the deleted macro- or micro-object.
Trash Resource The resource in which the deleted micro-object was stored.
Trash Code The code of the deleted driver, trailer or passenger which was used for assignment to units.
Trash Unique ID The unique ID of the deleted unit.
Trash Phone number The phone number from the properties of the deleted object.
Trash Object deleter The user who deleted the object.
Trash Unit deletion reason The reason given by the user at the time of deleting the unit in CMS Manager.
To see the list of all objects of the same type that have custom or administrative fields created in their properties, select the required filter (custom or admin fields respectively), type the characters ?* in the Text field, and click Search. In the same way, you can find all the units that belong to groups or have a specified unique ID, phone number, or completed profile fields in their properties.
Search text
A search request is entered in the Text field. When entering it, you can use special characters.
Character Use Example
(for searching for units by name)
Asterisk (*) Replaces any combination of allowed characters. You can type it at the beginning, middle or end of the request and use it any number of times. If the request is hnda*, the table of results displays all Hondas and Hyundais.
Question mark (?) Replaces any single character. Used in the same way as an asterisk (*). If the request is audi rs?, the table of results displays Audi RS3, Audi RS4, Audi RS5, and so on.
Comma (,) Used to separate different parts of the request from one another (without spaces). If the request is man,iveco, the table of results displays all MANs and Ivecos.
Exclamation mark (!) Used to exclude certain items from search results. If the request is !man the table of results displays all items, except for MANs and other units which have the combination of characters man in their name.
