General properties
The window of sensor properties, which opens when creating, editing, or copying a sensor, consists of the General and Calculation table tabs.
On the General tab, you can specify the name and parameter of the sensor, configure colors for sensor value intervals, and so on. The table below describes in detail the fields available on the tab. The required fields are marked with an asterisk (*).
Field Description
Name* The name of the sensor in the system.
Sensor type The sensor type which you can select from the list of available ones. The sensor should correspond to the characteristics of the device used for the unit, otherwise, the calculations may be incorrect.
Description Additional information about the sensor. This information is shown in the sensor table on the Sensors tab in the unit properties.
Parameter* The parameter the values of which are sent by the device and which should be used for the sensor being created. You can select the parameter in the drop-down list or enter it manually. You can specify it in the form of an expression using several parameters in the field.
Measurement system Select the measurement system that matches the units in which the sensor receives parameter values from the tracker (for example, kilometers or miles for mileage, liters or gallons for fuel, °C or °F for temperature). The system uses this setting to correctly interpret the incoming values. This field is displayed only for mileage, fuel, weight, and temperature sensors. This setting doesn’t affect how sensor values are shown in the work list, tooltips, or reports. In the work list and tooltips, values are converted according to the user’s measurement system. In reports, values are converted according to the measurement system selected in the report template settings.
Unit of measurement This field is taken into account only for the sensor types for which you can edit units of measurement: digital sensors, engine efficiency sensor, counter sensor, custom sensor. For example, instead of On/Off for digital sensors, you can specify Activated/Deactivated, Laden/Unladen, Open/Closed, and so on. The values of the mentioned sensors are displayed in the units specified in this field.
The values of the sensors for which you can’t edit the unit of measurement are shown in the work list, unit and track tooltips in the measurement system selected in the user settings. In reports their values are displayed in the measurement system selected in the report settings.
Last message only The option which, when enabled, allows calculating the sensor value in the unit tooltip and extended information only based on the last message. If the last message doesn’t contain the required data, a dash is displayed instead of the value. This option is not applied to the tooltips of track points.
If the option is disabled, the sensor value is calculated based on the last value of the parameter, regardless of how long ago it was received. In this case, the calculation may take up to 1 minute.
This option doesn’t influence the display of sensor values in Wialon for Android/iOS because the application uses data processed in real time.
Validator The sensor which is used to convert the values of the main sensor. After selecting a sensor in the list, in the Validation type field, you should select the operation which should be applied to the values of the main sensor and the validation sensor.
See the following pages for a description of the additional fields and options available for some sensor types:
Intervals and colors
In this section, you can create sensor value intervals, select a color, and specify a caption for each interval. The intervals must be specified for the sensor values obtained after applying all transformations: expression parameters, calculation table and validation.
By default, all the sensors have one infinite interval (from -∞ to +∞) colored in black.
Creating intervals
The intervals on the tab are displayed in two modes:
  • in the scale mode
  • in the table mode
To create intervals in the scale mode, follow these steps:
  1. Click on the scale or the icon .
  2. In the Interval field, specify the interval beginning and end. If the first field is not filled in, its value corresponds to -∞. If the second field is not filled in, its value corresponds to +∞.
  3. In the Text field, enter a caption for the interval.
  4. Select a color using the palette, spectrum, or Hex format.
  5. Click OK.
  6. Follow steps 1–5 for the required number of intervals.
To edit an interval, click on it and specify new values. To delete all intervals, click on the icon .
To create intervals in the table mode, follow these steps:
  1. Click on the Add range button.
  2. In the From field, enter the initial value of the first interval, select a color for it, and specify a caption. If the From field is empty, it is considered that -∞ is specified there.
  3. Follow steps 1–2 for the required number of intervals.
To delete an interval, click on the icon  .
Using intervals
The created intervals (their colors and captions) can be used in the following places of the monitoring system:
In the first three cases, you should go to the Advanced tab of the unit properties and select a sensor which should be used for these interface elements.
