Check points
The Check points table displays information about the checkpoints that were set when creating the route and the visits to these checkpoints.
The Check points table can include the columns described below.
Column Description
Point name The name which is given to this checkpoint while creating it.
Real arrival The time when the unit entered the checkpoint.
Scheduled arrival The time when the unit was supposed to enter the checkpoint according to the schedule.
Initial location The location at the time of entry.
Real departure The time when the unit left the checkpoint.
Scheduled departure The time when the unit was supposed to leave the checkpoint according to the schedule.
Final location The location at the time of departure.
Result Visited (both entrance and exit were detected), Entrance only, Exit only, Skipped, Finished (entrance to the last point was detected).
Route The name of the route to which this checkpoint belongs.
Schedule The name of the schedule.
Ride The name of the ride.
Arrival time deviation A positive value if delayed, negative value if in a hurry in regards to the arrival time set in the point properties.
Departure time deviation A positive value if delayed, negative value if in a hurry in regards to the departure time set in the point properties.
Presence duration The time spent at the checkpoint.
Presence mileage The mileage at the checkpoint.
Section duration The time spent to travel from the previous checkpoint to the current one.
Section mileage The mileage from the previous checkpoint.
Count The number of points.
Driver The name of the driver (if available).
Trailer The name of the trailer (if it was assigned).
Notes An empty column for your custom comments.
Questions and answers
Reports show incorrect mileage. What should I do?
Possible explanations and actions:
1. Outliers of data.
To detect such outliers, build a track of unit movement for the appropriate period. Outliers of data will be seen on the track as dashed lines.
Ways to overcome outliers:
  • Enable filtering of unit positional information in messages (on the Advanced tab of unit properties). This will not affect old messages but applied to new ones.
  • To correct data in reports, change settings of trip detection, in particular, reduce Maximum interval between messages and increase Minimum satellites.
2. Incorrect settings or operation of the mileage counter.
  • Check the mileage counter settings on the General tab of unit properties.
