Additional unit information
You can find additional information in the unit tooltip and in the extended unit information in the work list on the Monitoring tab.
Additional information includes the following data: the time of receiving the last message, location, presence in geofences, distance to the nearest geofence, speed, altitude, counters, satellites, connectivity settings, unit icon, sensor values, parameters, assigned drivers and trailers, custom fields, and maintenance intervals.
The label with the deactivation date can also be displayed for units within the services in which the activation code feature is enabled. This requires the Deactivation date option to be selected in the user settings.
All the data items are activated in the Show additional information about the unit section of the user settings, except for the distance to the nearest geofence. This item is adjusted by the Distance from unit to geofence option from the Basic section.
Unit tooltip
The information on the driver’s working and rest hours and violations displayed for the assigned driver has the Legacy status: it’s no longer developed or maintained.
A unit tooltip is shown when you point to a unit. You can select the contents of the tooltip in the user settings.
An example of a unit tooltip is displayed in the picture above. The following icons are used in the tooltip to denote indicators:
| Icon | Indicator |
Speed |
Altitude |
Engine hours |
Mileage |
Number of satellites |
Unit tooltips don’t show coordinates, but they have the Copy coordinates feature (the icon
in the address line) adjusted by the Location option in the user settings. Coordinates are copied with degrees as a decimal fraction, and a comma is used as the latitude and longitude separator.
The profile properties are displayed in the tooltip in the same order as they appear on the Profile tab of the unit properties.
You can copy data from the tooltip by selecting and saving the required fragment to the clipboard.
Extended unit information
Apart from the tooltip, you can obtain additional information about the unit by clicking on the unit icon in the work list on the Monitoring tab (both in the unit and unit group modes). The content of the extended unit information is also adjusted in the user settings.
You can open the extended information for any number of units in the work list. To hide the extended information, click on the unit icon again.
Depending on the unit settings, the values indicated in the tooltip as well as in the expanded information can be in the metric (kilometers, meters, kilometers per hour, liters), American (miles, feet, miles per hour, gallons), or imperial (miles, feet, miles per hour, gallons) measurement systems.
Opening the map of a third-party source
When you click on the icon
in the extended information or in the tooltip, it is possible to go to the site of a third-party map source. The icon becomes available after the activation of the Location option and is shown in the address line.
To use this feature, select one of the following maps in the user settings:
- Google,
- Regional,
- Bing,
- OSM.
If several maps are selected, a click on the coordinates opens the one that is higher on the list.
Monitoring options menu
To open the menu of monitoring options, click on the required unit on the map. This menu contains the same functions that are selected for the work list of the Monitoring tab. In addition, regardless of the selected options, the menu always contains the icons for generating a quick report and building a quick track.
The menu of monitoring options doesn’t contain information about the unit location, the tracking option, and the icon for removing the unit from the work list even if they are selected as monitoring options.
When a unit moves on the map, the menu moves with the unit. To close it, click anywhere outside the menu.
