Transferring unit properties
You can copy most of the properties from one unit to another or save them to a WLP file using the import and export tool. The exceptions are:
  • user access rights;
  • unit group membership;
  • information about the creator and the account.
To export unit properties, select the Export to WLP item in the user menu and select Unit in the Export from drop-down list. See a detailed guide here.
To add the properties of one unit to another using a WLP file, select the Import from WLP item in the user menu and follow the guide.
Exportable properties
Below are the unit properties you can export.
Property Description
General properties The device type, name, phone number(s), unique ID, access password (the General tab).
Icon The icon of the unit and the state of the Rotate icon option.
Device configuration The parameters of the device configuration. They can be available for some types of devices on the General tab after clicking on the icon .
Counters The current values of counters and the state of the options for calculating them (the General tab).
Report properties The parameters from the Additional settings, Speeding, and Driver activity sections of the Advanced tab.
Advanced properties The speed source, the color parameters and the message validity filtering parameters from the Advanced tab.
Sensors The contents of the Sensors tab. Below you can find more information about the import of sensor validators.
Custom fields The contents of the Custom fields tab.
Administrative fields The administrative fields from the Custom fields tab.
Commands The contents of the Commands tab.
Eco Driving The contents of the Eco driving tab. Below you can find more information about the import of eco driving criteria.
Profile The contents of the Profile tab. Below you can find more information about the import of vehicle types.
Trip detector The contents of the Trip detector tab.
Service intervals The contents of the Service intervals tab.
Health check The contents of the Health check tab.
Import of eco driving criteria
If you import eco driving criteria and select the Replace or Merge import types, the system always applies the Replace type, that is, the previous criteria are deleted and the new ones are entered. If you select the Append type and the destination unit has some criteria which are different from that of the source unit, then these criteria remain the same and the new ones are not added. If the destination unit has no such criteria, the system adds the new ones.
If sensors or sensor validators are specified in the parameters of the eco driving criteria, then you should import these criteria together with the sensors or create the same sensors in the destination unit properties beforehand (see below).
Import of sensor validators
When importing sensors, the validator is saved only if the set and order of sensors in the source unit are completely identical to the ones of the unit to which they are imported.
Import of vehicle types
To import and export the profile properties of the unit, you should have the Manage custom fields access right to it.
You can import the vehicle type to the unit properties. To do this, you should specify the key of the vehicle type in the import file.
You can see the keys of vehicle types in the tables below.
The keys of cargo transport types:
Vehicle type Key
Pickup pickup
Van van
Truck truck
Heavy truck heavy_truck
Dump truck dump_truck
Logging truck logging_truck
Tractor unit tractor_unit
Trailers and semi-trailers trailers_semi
Tanker trailer tanker_trailer
Tank truck tank_trailer
Refrigerator van refrigerator_van
Other other_cargo
The keys of passenger transport types:
Vehicle type Key
Kick scooter kick_scooter
Bicycle bicycle
Motorcycle motorcycle
Passenger car passenger_car
Minibus minibus
Bus bus
Trolleybus trolleybus
Tram tram
Other other_passenger
The keys of special machinery types:
Vehicle type Key
Agricultural machinery
Tractor tractor
Combine combine
Sprayer sprayer
Baler baler
Agricultural spreader agricultural_spreader
Mower mower
Construction equipment
Bulldozer bulldozer
Excavator excavator
Backhoe loader backhoe_loader
Loader loader
Skid-steer loader skid_steer_loader
Forklift forklift
Hooklift hooklift
Crane crane
Manipulator manipulator
Bucket truck bucket_truck
Concrete mixer concrete_mixer
Concrete pump concrete_pump
Piling and drilling rig piling_drilling_rig
Crusher crusher
Trencher trencher
Pipelayer pipelayer
Road roller road_roller
Road grader road_grader
Paver paver
Scraper scraper
Feeder feeder
Special vehicles
Ambulance ambulance
Garbage truck garbage_truck
Fire truck fire_truck
Street cleaning machine street_cleaning_machine
Tow truck tow_truck
Other other_special
The keys of other vehicle types:
Vehicle type Key
Air transport air_transport
Off-road vehicle off_road_vehicle
All-terrain vehicle all_terrain_vehicle
Snowmobile snowmobile
Snowcat snowcat
Rail transport rail_transport
Water transport water_transport
Recreational vehicle recreational_vehicle
Other other_vehicle
