Unfinished trips
See the Trips between geofences article to learn how to prepare trips for this report.
The Unfinished trips table shows the unit’s incomplete trips from one geofence to another. A trip is considered to be unfinished when the unit leaves the starting point, and then, not having visited any of the final points, again appears in the point marked as the beginning. It can be the same zone from where the unit left (if circle trips are not allowed) or some other geofence with a starting point mark.
The Unfinished trips table contains the columns described below.
Column Description
Trip The departure and destination point.
Trip from The departure point.
Trip to The destination point.
Beginning The date and time when the trip began.
End The date and time when the trip ended.
Mileage The distance travelled during the trip.
Mileage (adjusted) The mileage subject to the coefficient set in the unit properties on the Advanced tab.
Trip duration The amount of time it took to perform the trip.
Total time The time from the beginning to the end of trip. It is recommended to use this column in combination with the grouping parameter or the Total row. If the Total row is configured in the table, it shows all the time that elapsed from the start of the first trip to the end of the last one.
Parkings duration The time spent on parkings.
Avg. speed The average speed calculated for the trip. See how the average speed is calculated on the Data in reports page.
Max. speed The maximum speed registered during the trip.
Driver The name of the driver (if identified).
Trailer The name of the trailer (if it was assigned).
Counter The counter sensor value.
Initial counter The value of a counter at the moment of leaving a departure geofence.
Final counter The value of the counter at the moment of entering a destination end.
Avg. temperature The average temperature during the trip.
Min. temperature The minimum temperature during the trip.
Max. temperature The maximum temperature during the trip.
Initial temperature The temperature at the beginning of the trip.
Final temperature The temperature at the end of the trip.
Count The number of trips (can be helpful either when grouping the table data by years/months/weeks/days/shifts or for the reports on unit groups).
Status The unit status registered during the trip. It can be registered manually or automatically by means of a notification. If there are several registered statuses, the first of them is displayed.
Fuel consumed The volume of consumed fuel detected by any sort of fuel sensor. If several such sensors are available, their values sum up.
Consumed by ImpFCS The volume of consumed fuel detected by an impulse fuel consumption sensor.
Consumed by AbsFCS The volume of consumed fuel detected by an absolute fuel consumption sensor.
Consumed by InsFCS The volume of consumed fuel detected by an instant fuel consumption sensor.
Consumed by FLS The volume of consumed fuel detected by a fuel level sensor.
Consumed by math The volume of consumed fuel calculated by math.
Consumed by math for FLS The volume of consumed fuel calculated by math based on the data from a fuel level sensor (FLS).
Consumed by rates The volume of consumed fuel calculated by rates.
Energy consumed The amount of battery energy in kWh consumed during the trip. It is calculated using the readings of the battery level sensor.
Avg. fuel consumption The average fuel consumption by any sort of fuel sensor. If several such sensors are available, their values sum up.
Avg. consumption by ImpFCS The average fuel consumption during the trip detected by an impulse fuel consumption sensor.
Avg. consumption by AbsFCS The average fuel consumption during the trip detected by an absolute fuel consumption sensor.
Avg. consumption by InsFCS The average fuel consumption during the trip detected by an instant fuel consumption sensor.
Avg. consumption by FLS The average fuel consumption during the trip detected by a fuel level sensor.
Avg. consumption by math The average fuel consumption during the trip calculated by math.
Avg. consumption by math for FLS The average fuel consumption during the trip calculated by math based on the data from a fuel level sensor (FLS).
Avg. consumption by rates The average fuel consumption during the trip calculated by rates.
Avg. energy consumption The average battery consumption in kWh per 100 km or mi during the trip. It is calculated using the readings of the battery level sensor.
Initial fuel level The fuel level at the beginning of the trip.
Final fuel level The fuel level at the end of the trip.
Max. fuel level The maximum fuel level.
Min. fuel level The minimum fuel level.
Initial battery level The battery level in kWh at the beginning of the trip.
Final battery level The battery level in kWh at the end of the trip.
Max. battery level The maximum battery level in kWh within the trip.
Min. battery level The minimum battery level in kWh within the trip.
Penalties The penalties calculated for the adjusted Eco driving criteria. Penalty averaging for grouping rows (group headings) can be adjusted in report settings.
Rank The received penalty points converted into a grade using a 10-point scoring system.
Notes An empty column for your custom comments.
Video Files saved during the trip using the Video module. To watch them, click on the icon 📹 (the number of grouped files is indicated to the right of it, if several). If several grouped files are available, you can select the required one in the drop-down list in the upper-left corner. The column is available if the Video monitoring service is activated in the account properties.
Image The images received from the unit. Viewing images in reports and the functions available while doing this are described here.
See the Trips between geofences article to find out more information about the additional parameters for Unfinished trips table.
Questions and answers
Reports show incorrect mileage. What should I do?
Possible explanations and actions:
1. Outliers of data.
To detect such outliers, build a track of unit movement for the appropriate period. Outliers of data will be seen on the track as dashed lines.
Ways to overcome outliers:
  • Enable filtering of unit positional information in messages (on the Advanced tab of unit properties). This will not affect old messages but applied to new ones.
  • To correct data in reports, change settings of trip detection, in particular, reduce Maximum interval between messages and increase Minimum satellites.
2. Incorrect settings or operation of the mileage counter.
  • Check the mileage counter settings on the General tab of unit properties.
What is the difference between time-based and mileage-based calculation of fuel level?
1. Mileage-based calculation
In a standard situation, all calculations of fuel level are mileage-based. That means data from the FLS is taken only during intervals of movement (trips). Those trips are defined according to parameters set in the trip detector.
Drains and fillings are detected if there is a difference between the fuel level on the following movement interval (X) and the fuel level on the previous movement interval (Y). If (X — Y) > 0, it is a filling; if (X — Y) < 0, it is a drain; if X = Y, it is neither. Of course, there can be some inaccuracy in data coming from the FLS. That is why, to avoid false drains and fillings, set the following parameters in the FLS properties:
  • minimum fuel filling volume,
  • minimum fuel drain volume,
  • minimum stop duration to detect a fuel drain,
  • and some others.
2. Time-based calculation
This type of calculation is more complicated and is based on the following algorithm: the speed of the decrease of fuel level according to the FLS is compared with the consumption calculated mathematically. The time-based calculation is necessary for stationary units. It is also widely used for moving units for controlling drains during the movement, for example.
Example
A vehicle stayed at a parking lot during 10 hours. Defueling was made in small portions over the whole parking period. As a result, 60 liters of fuel were drained. It is possible to determine if it was a drain o fuel consumption according to the state of the unit’s ignition sensor. ​
Why doesn't consumption by math work?
Since the consumption math mechanism is based on the values of the ignition sensor, check its properties and operation. You may not have this sensor created or there may be 0 l/h indicated for the fuel consumption in its properties.
How to configure consumption by math if the unit doesn't have ignition?
You may use one of the approaches described below.
Variant 1
Create a virtual ignition sensor. We recommend that you use average speed (speed+#speed)/const2 as its parameter.
Variant 2
Even if you haven’t installed an ignition sensor in the unit or are not sure of the name of the parameter that responds for the ignition, in the parameters of the device there may be some characteristic that corresponds to the operation of the engine. To use it, compare two messages from the unit: one — when the ignition the most probably off; the other — when it’s on.
Example
During a long time interval the unit sends approximately the following set of parameters:
Copied!
While moving at some speed — approximately the following:
Copied!
Straight before the start of the movement, as a rule, the ignition turns on:
Copied!
Discard the parameters that are obviously imprecise: hdop (precision), adcN (it’s difficult to determine the regularity), odo (relative odometer in meters), mcc mnc cell_id and lac (LBS data section), gsm_lvl (the level of the GSM signal), etc. The parameter J1708_eng_hrs for this unit seems the most probable, as it doesn’t change during the night parking. As a rule, it is also possible to use pwr_ext. Is the ignition is digital, you can follow the values’ changes in the block ‘I/O =’ (see more details in the Inputs and outputs section).
Variant 3
If you have already connected the ignition, find out its parameter by means of the method described above or from the manual of the manufacturer.
Why does mathematical calculation show enormous values?
Possible reasons:
  • In some cases, the system may consider that during the interval with no messages from the unit its ignition was on. Adjust the default value ‘0 seconds’ on the Maximum interval between messages option on the Advanced tab of unit properties. The influence of the option on the fuel calculation is described in the documentation.
  • Several engine efficiency sensors can be created. Check up their values. The easiest way to evaluate it is to create in a report a simple chart with one of the curves Fuel consumption by math.
How to determine fuel consumption, if I know how much fuel the unit consumes within the city, and how much outside it?
Let us suppose that the fuel consumption in the urban cycle is 10 l/100 km and 7 l/100 km — in the suburban cycle.
  • Create an ignition sensor (as in the example above) and set 1 l/h for the consumption during idling.
  • The average consumption in the urban cycle is 36 km/h, in the suburban — 80 km/h.
  • The unit will cover a distance of 100 km driving at a speed of 36 km/h in 2.8 hours. 10 l / 2.8 = 3.57. Let us calculate the value of the increasing coefficient when moving in the city: 3.57 / 1 (idling) = 3.57.
  • As a result of a similar calculation for the suburban cycle, we obtain the coefficient equal to 5.6.
  • Create an engine efficiency sensor, taking into account the fact that the unit cannot consume less fuel than during the idling, and that it is stationary before the beginning of the movement. As a parameter we use the average speed (speed + # speed) / const2 and fill in the calculation table (manually or using the calculation table wizard):
Note that the last pair of points is how the system calculated before (the fuel consumption was considered constant for a speed above 80 km/h). You cannot use this method and change the set of points. Also ‘3’ in this example is the minimum speed from the unit’s trip detector, consequently, this parameter can be different for your unit.
Result: in our example, the average consumption has been calculated for the unit. It has been calculated relative to the speed and time between messages and taking into account the values of the vehicle operation.
How does the mathematical calculation algorithm work?
During the mathematical calculation, fuel consumption is computed separately for each pair of messages.
The following algorithm is used:
  1. The status of each engine sensor (engine ignition, absolute and relative engine hours sensors) in the current message is determined.
  2. For the operating sensors the values indicated in the field Consumed, l/h of their properties are summed.
  3. The values of the engine efficiency sensors bounded to the engine sensors are calculated.
  4. The received values are summed according to the formula k1 + (k2 - 1) + (k3 - 1) + … + (kn – 1). In that way, the coefficient is formed. If the sum of the coefficients is less than 0 or invalid, the total coefficient will be 1.
  5. To determine the current fuel consumption of the unit, the value from point 2 is multiplied by the value of point 4.
  6. The value from the previous message till the current one is multiplied by the value from point 5.
  7. The consumption for each message pair for the indicated interval is summed and in that way, the fuel consumption is determined by consumption math.
