Connection problems
The Connection problems table lists the time periods when the system did not receive data from the unit. The parameters for this table are adjusted on the Advanced tab of the unit properties where you set Maximum interval between messages.
Below is the information which can be presented in the Connection problems table.
ColumnDescription
BeginningThe date and time when connection loss happened.
EndThe date and time when the connection was recovered.
DurationThe time interval of connection loss.
LocationThe address where the unit was right before the loss of connection.
CountThe number of connection gaps detected in a certain time interval (it is advisable when grouping rows by days/weeks/months or for reports about groups of units).
DriverThe name of the driver (if available).
TrailerThe name of the trailer (if it was assigned).
Video
Files saved during the connection loss using the Video module. To watch them, click on the icon (the number of grouped files is indicated to the right of it, if several). If several grouped files are available, you can select the required one in the drop-down list in the upper-left corner.
The column is available if the Video monitoring service is activated in the account properties.
ImageThe images received from the unit. Viewing images in reports and the functions available while doing this are described here.
Additional filtering by driver, trailer, and geofences/units can be applied to the Connection problems table.
Questions and answers
