Report сategories
This page contains a list of all report tables by topics. Tables are the primary way to display data in reports. Each table type has its own separate set of columns and parameters.
Reports on units are available in the module Basic reports, reports on a group of units and other objects can be found in the Advanced Reports module.
Unit mobility
These reports can help you to control the movement of a unit, see all its trips, stops, parkings. You can attach a map with tracks and markers to such reports.
Geofences
Geofences are areas marked on the map. Using these reports, you can track which geofences the unit has visited or left, how long it has been there, and more.
Fuel
With a fuel level sensor, you can get data on fuel consumption, level, fillings, and drains.
Fuel information is also available in the following tables:
Battery charge of electrical vehicles
With a battery level sensor, you can get data on battery consumption, level, and charges.
Battery charge information is also available in the following tables:
Sensors, counters, parameters in messages
These reports allow you to track traffic, mileage, engine hours, analyze parameter values ​​from unit messages.
Eco Driving, driver's work mode
Reports in this category contain data on the driver’s compliance with work and rest standards and on their potentially dangerous driving style: sudden braking and acceleration, speeding, idling, etc.
Route progress
In these reports you can find the points visited by the unit, how much it deviated from the planned schedule. A separate report on orders is provided to display data from the Logistics application.
Communication with the unit and the driver, commands
All messages, commands, photos and video files sent can be displayed in a table. You can also know when the connection with the unit has been lost.
Assigning drivers, trailers, passengers
Using these reports, it is possible to control the shifts of drivers, the assignment of trailers or other equipment to the unit, the entry and exit of passengers from the vehicle.
User actions in the system and data entered by the user
In the reports, you can see which user made changes to macro-objects in the system: units, unit groups, resources, etc., and what kind of changes these were. You can also build a report with data entered manually by the user: unit profile, custom fields.
Fleet management
Using these tables, you can control the maintenance schedule of vehicles or equipment and get data on their operation cost.
Unit history
These tables show unit message data for the interval, events recorded manually in the unit history or via notifications and tasks, and information about notification triggering for a unit.
