Sensor types
When creating a sensor, you should select its type in accordance with the principle of its operation and the equipment used.
Take into account the current limitation for the size of the numerical parameter value sent by the sensor.
The types of sensors provided in the Wialon system are divided into six groups:
The sensors from each group are described below.
Mileage
This group includes sensors which are used to determine the traveled distance.
| Sensor type | Units of measurement | Description |
| Mileage sensor | km (kilometers), mi (miles) | The sensor which shows the distance travelled by the unit. You can use it in the trip detector to detect trips and parkings and in the mileage counter. |
| Relative odometer | km (kilometers), mi (miles) | The sensor which shows the distance travelled by the unit since the last message was received from it. You can use it in the trip detector to detect trips and parkings. |
Digital
This group consists of sensors which can have only two states. For example, on/off, activated/deactivated, and so on.
| Engine ignition sensor | On/Off or any |
The sensor which shows whether the ignition is on or off. You can use it in the trip detector to detect trips and parkings and in mileage and engine hours counters. In addition, you can use the engine ignition sensor to detect fuel drains at idle. To do this, you should specify the fuel consumption rate at idle in the Consumption, liters per hour field. |
| Alarm trigger | On/Off or any |
The sensor a non-zero value of which allows marking a message as an alarm one (SOS). The messages registered in the system before the creation of the sensor are not marked as alarm ones. |
| Private mode | On/Off or any |
The sensor which is used to determine whether a trip is business or private. If the sensor is enabled during a trip, it is considered private. To see such trips in a report, configure filtering by the enabled private mode sensor, and to see business trips, by the disabled one. You can activate the Do not show unit location option in the sensor properties, so that no location data is transmitted in messages from the unit during private trips. This affects the display of the unit and the acquisition of its data as follows:
| Real-time motion sensor | On/Off | The sensor which determines the movement state of units in real time. The movement state determined by the sensor is shown on the map and in the work area on the Monitoring tab. To do this, the Replace unit icons with motion state signs option should be enabled in the user settings as well as the Motion state option on the Monitoring tab. The sensor readings can be based on the values of speed, ignition, engine revolutions, etc. As for other sensor types, you can specify an expression parameter and configure validation. |
| Custom digital sensor | On/Off or any |
The custom sensor which has two states: on/off, activated/deactivated, etc. |
If a non-digital parameter is specified for a digital sensor, then any numerical value other than 0 is considered as an enabled state. In such cases, it is advisable to configure a calculation table so that all incoming values are converted to 0 or 1. This avoids distortions in formula calculations and in the mathematical calculation of fuel consumption.
If no units of measurement are specified for a digital sensor, its values are considered as numbers, not as an enabled or disabled sensor state.
Gauges
This group contains sensors which are used to measure values such as voltage, weight, acceleration, temperature.
| Voltage sensor | V (volts) | The sensor which shows the voltage value. For example, this value can be used to determine temperature or the ignition state. |
| Weight sensor | t (tons), pounds | The sensor which is used to determine the weight of transported goods. |
| Accelerometer | g | The sensor which is used to determine acceleration along the X, Y, Z axes, which allows detecting a collision, that is, a road traffic accident. |
| Temperature sensor | °C (degrees Celsius), °F (degrees Fahrenheit) | The sensor which shows the temperature value or any other parameter. You can use the temperature sensor to analyze received values. See a configuration example. |
| Temperature coefficient | none | The coefficient which is used to calculate the fuel level at different temperatures in the tank more precisely. See a configuration example. |
Engine
This group includes sensors which are used to measure values associated with the engine operation.
| Engine revolution sensor | rpm (rounds per minute) | The sensor which shows the frequency of engine revolutions. |
| Engine efficiency sensor | any | The sensor which is used to determine the movement coefficient under load, which is used to calculate the fuel consumption. The sensor can function as a reduction coefficient if its values are from 0 to 1. You can specify any unit of measurement for this sensor. |
| Absolute engine hours | h (hours) | The sensor which shows the total number of engine hours. |
| Relative engine hours | h (hours) | The sensor which shows the number of engine hours, taking into account the work intensity coefficient. See a configuration example. |
Using relative and absolute engine hours, you can also detect fuel drains at idle. To do this, you should specify the fuel consumption rate at idle in the Consumption, l/h field.
Fuel and energy
This group consists of sensors which can be used to determine the amount of consumed fuel and the fuel level in the tank, as well as to monitor the level and consumption of an electric vehicle battery.
Impulse fuel consumption sensor
Units of measurement: l (liters), gal (gallons)
The sensor which shows the accumulated value of impulses. See the algorithm of calculating fuel consumption on the Additional properties page. To convert the received value into the amount of consumed fuel, you should configure the calculation table and activate the Calculate fuel consumption by sensor option. To set an overflow value for the sensor, specify it in the Maximum impulses field. For sensors of this type, the calculation table is applied to the difference between two messages in a row. If the device sends not the accumulated value of impulses but the number of impulses between messages, you should use the instant fuel consumption sensor.
Absolute fuel consumption sensor
The sensor which shows the fuel consumption for the entire period of the vehicle operation. To get data on the fuel consumption for a specific period, you should take the sensor values at the end of the selected period and subtract the sensor values at the beginning of the period. In the sensor properties, you should enable the Calculate fuel consumption by sensor option.
Instant fuel consumption sensor
The sensor which shows the amount of consumed fuel since the previous measure (message). In the sensor properties, you should enable the Calculate fuel consumption by sensor option.
Fuel level sensor
The sensor which determines the fuel level in the tank. In the sensor properties, you should enable the Calculate data by the sensor option. See a configuration example.
Impulse fuel level sensor
This sensor determines the fuel level in the tank using an impulse signal from a flow or level meter. When calculating the amount, the difference in the values of the impulses from two messages in a row is divided by the time difference between them.
Example. The tracker sends three messages with the following timestamps and impulse counter values: 08:17:03 – 0, 08:17:07 – 100, 08:17:10 – 200. The system calculates the value for each pair of adjacent messages using the formula Value = ΔImpulses / ΔTime:
Value 1 = (100 − 0) / (4 s) = 25Value 2 = (200 − 100) / (3 s) = 33.33
Each value is then converted into a fuel level value using the sensor calculation table. After conversion, the value is processed by the standard fuel level algorithm (filtering, filling and drain detection, consumption calculation).
This type of sensor is rarely used in practice. In most cases, a standard fuel level sensor (FLS) is preferred.
Battery level sensor
Units of measurement: kWh
The sensor that indicates the battery level of the electric vehicle. For the sensor to be used in the system, enable the Calculate data by the sensor option in its settings.
This sensor allows performing the following actions in the monitoring system:
- including data on battery level, charge number and volume, battery consumption in reports: in charts, in the Fuel fillings and battery charges, Summary, Chronology, Engine hours, Trips tables and in the Statistics. For this purpose, the Calculate data by the sensor option should be enabled in the sensor properties;
- filtering data in report tables depending on whether there have been charges within these intervals;
- creating notifications of the Fuel fillings and battery charges type, which are triggered after a unit battery is recharged.
Other
This group includes a custom sensor and sensors which are used to control passengers, drivers, and trailers.
| Counter sensor | any | The sensor which allows determining the intensity of passenger traffic or the number of certain actions (for example, opening and closing the door). There are several types of such sensors:
You can specify any unit of measurement for this counter. In unit messages and tooltips, the values of this type of sensor are always rounded to hundredths. At the same time, the actual sensor values are not changed, so the calculations in the system are not affected. |
| Custom sensor | any | The sensor which can be configured to measure any value sent by the unit. You can specify any unit of measurement for this sensor. Sensors of this type can only use text and numeric parameters. See more details on how the text parameter values are displayed in the additional unit information, messages, reports and other locations on the Sensor parameters page. |
| Driver assignment | none | The sensor which can be used to detect the assignment of the driver to the unit. |
| Trailer assignment | none | The sensor which can be used to detect the assignment of the trailer to the unit. |
| Passenger sensor | none | The sensor which can be used to detect when passengers are picked up or set down. |
is shown next to the unit name on the map and in the work list.
