Reports on drivers
To generate reports on drivers or driver groups, you should have the Request reports and messages access right to the resource to which these drivers or groups belong. The driver and the report template should belong to the same resource.
The following types of tables can be applied to drivers:
Assignments
The Assignments table shows when and to which unit the driver was assigned, how long their work shifts lasted, how much fuel was spent, the distance traveled, etc.
The table can include the columns described below.
Column Description
Unit The name of the unit to which the driver was assigned.
Driver The name of the assigned driver (only in the report on the group of drivers).
Beginning The date and time when the driver was assigned to the unit.
Initial location The initial position, that is, the address at that moment (if available).
End The date and time when the driver was separated from the unit.
Final location The final position, the address at that moment (if available).
Duration The duration of a work shift.
Total time The time from the beginning of the first shift to the end of the last shift.
Engine hours The total amount of engine hours for a working interval of the driver.
Engine hours in movement The number of engine hours for the interval of movement with the assigned driver.
Engine hours in idle run The number of engine hours for the interval of idling with the assigned driver.
Mileage The distance traveled within the period.
Mileage (adjusted) The mileage taking into account the coefficient set in the unit properties on the Advanced tab.
Urban mileage The distance traveled at low speed.
Suburban mileage The distance traveled in the suburban area (at high speed). It is calculated in regards to speed. The urban/suburban speed line is indicated on the Advanced tab (the Urban speed limit setting).
Avg. speed The average speed on a given interval.
Max. speed The maximum speed registered within this work shift.
Counter The value of the counter sensor.
Status The status of the unit registered during the interval (if there are several, the first one is displayed).
Violations The number of violations.
Count The number of assignments found on a given interval.
Fuel consumed The amount of fuel consumed in total for all fuel sensors.
Consumed by ImpFCS The volume of consumed fuel detected by an impulse fuel consumption sensor.
Consumed by AbsFCS The volume of consumed fuel detected by an absolute fuel consumption sensor.
Consumed by InsFCS The volume of consumed fuel detected by an instant fuel consumption sensor.
Consumed by FLS The volume of consumed fuel detected by a fuel level sensor.
Consumed by math The volume of consumed fuel calculated by math.
Consumed by math for FLS The volume of consumed fuel calculated by math based on the data from a fuel level sensor (FLS).
Consumed by rates The volume of consumed fuel calculated by rates.
Energy consumed The amount of consumed battery energy in kWh calculated using the readings of the battery level sensor for the interval during which the driver was assigned to a unit.
Avg. fuel consumption The average fuel consumption, determined from the available fuel sensors.
Avg. consumption by ImpFCS The average fuel consumption during the trip detected by an impulse fuel consumption sensor.
Avg. consumption by AbsFCS The average fuel consumption during the trip detected by an absolute fuel consumption sensor.
Avg. consumption by InsFCS The average fuel consumption during the trip detected by an instant fuel consumption sensor.
Avg. consumption by FLS The average fuel consumption during the trip detected by a fuel level sensor.
Avg. consumption by math The average fuel consumption during the trip calculated by math.
Avg. consumption by math for FLS The average fuel consumption during the trip calculated by math based on the data from a fuel level sensor (FLS).
Avg. consumption by rates The average fuel consumption during the trip calculated by rates.
Avg. energy consumption The average battery consumption in kWh per 100 km or mi calculated using the readings of the battery level sensor during the interval when the driver was assigned to a unit.
Initial fuel level The fuel level at the beginning of the work shift.
Final fuel level The fuel level at the end of the work shift.
Initial battery level The battery level in kWh at the beginning of the interval during which the driver was assigned to a unit.
Final battery level The battery level in kWh at the end of the engine hours interval during which the driver was assigned to a unit.
Penalties The penalties calculated for the adjusted Eco driving criteria.
Rank The penalty points, converted into a grade using a 10-point rating system.
Notes An empty column for your custom comments.
In addition, on the Bind tab of the report template, you can select the units to which the report should be applied. If no units are selected in this section, the report will be applied to all available units.
The Assignments table is designed in such a way that the first column is the list of units to which the driver was assigned. It is recommended to apply the detalization option to this table to get a possibility to expand any unit and see more detailed information about all work shift.
To determine the intervals of the assignment, the messages from the unit are also taken into account. If there are such messages, they are considered to be of more priority than the messages about the assignment (the intervals are counted according to them).
Settings
You can apply the following settings to the Assignments table:
In reports on driver groups, the Total setting isn’t available.
Grouping and sorting
You can group the data in the Assignments table by the following parameters: total, unit, year, season, month, week, day, day of the month, date, shift, duration. You can also sort the data in the table.
In reports on driver groups, you can also group the data by driver.
Interval filters
You can apply the following interval filters to the Assignments table:
Custom fields
The Custom fields table shows the list of custom fields entered in the corresponding tab of the driver’s properties. It can be generated for an individual driver as well as for the whole group.
The available columns are listed below.
Column Description
Driver The name of the driver (only in the report on the group of drivers).
Name The custom field name.
Value The custom field value.
Settings
You can apply the following settings to the Custom fields table:
Grouping and sorting aren’t available for the Custom fields table in reports on drivers. In reports on driver groups, you can group the data by the following parameters: total, driver.
Interval filters
You can apply the following interval filters to the Custom fields table:
Driver activity
This functionality has the Legacy status: it’s no longer developed or maintained.
The Driver activity table shows such information as the type of driver’s action, the crew of a vehicle, the state of the tachograph cards. It can include the columns described below.
Column Description
Beginning The date and time when the activity begins.
Card The state of the digital tachograph (inserted/not inserted).
Activity The type of driver’s activity (rest, work, driving, available, not available).
Source The source of data, which is used to generate information about driver activity. The following column values are available: E — the data about trips is used; T — the tachograph data is used; U — the data about driver separation is used; None — the data source is unknown.
Unit The name of the unit to which the driver is assigned.
Driving The time of driving.
Work The hours of active work (time spent by the driver on vehicle repair, fuel filling, etc.).
Availability The hours of passive work (time spent by the second driver in the moving vehicle).
Rest The time for rest of the driver (vehicle is stopped, the driver rests in a specially designated place).
Overall work The total time spent by the driver on such actions as driving, work, reserve.
Slot The slot for digital tachograph card (driver or co-driver).
Status The vehicle crew size (single/crew).
Daily mileage The distance covered by the assigned driver during the day (24 hours).
The last row of the table shows 0:00:00 instead of the duration value for all activity types, because the end time of the driver’s activity is unknown, regardless of the selected data source.
Settings
You can apply the following settings to the Driver activity table:
You can group the data in the Driver activity table by the following parameters: total, year, season, month, week, day, day of the month, date, shift, duration. You can also sort the data in the table.
Interval filters
You can apply the following interval filters to the Driver activity table:
  • Data source: files from the driver card, online data, assignments and trips
The “Eco driving” table
The Eco driving table for drivers and driver groups provides information on driver behavior and vehicle handling.
The Eco driving table for drivers contains all the columns of the Eco driving table for units. The table for driver groups also contains the following columns:
  • Rating by violations
  • Unit
The “Rating by violations” column
The Rating by violations column serves as a comparative scoring system that calculates an individual index number for each driver in the group based on:
  • violations, using the data from the Rank column;
  • mileage if the Rank data is the same.
To configure the Rating by violation column, follow the instructions on the Eco Driving table page.
In the completed report, the driver with the best performance is ranked 1. The drivers with more violations and lower mileage receive higher rating value.
The “Unit” column
The Unit column indicates the name of the unit to which a driver is assigned.
Settings
You can apply the following settings to the Eco driving table:
You can group the data in the Eco driving table by the following parameters: total, unit, trip, engine hours, violation type, year, season, month, week, day, day of the month, date, shift, duration. You can also sort the data in the table.
Interval filters
You can apply the following interval filters to the Eco driving table:
In reports on driver groups, the Score-based rating color filter is also available.
Infringements
This table shows the information on the violations of labor routine by the driver. The violations are determined in accordance with the AETR regulations.
Column Description
Time The date and time of the infringement registration.
If the driver has been driving for 6 hours or more, the infringement is registered at the moment when driving, excluding work, has lasted 6 hours (+/- 1 minute) from the start of movement. Such an infringement is considered very serious. If the driver has been driving for 5 to 6 hours, the infringement is registered at the moment when driving has lasted 5 hours, and if they have been driving for 4.5 to 5 hours, the infringement is registered at the moment when driving has lasted 4.5 hours. Such infringements are considered serious and minor, respectively.
Thus, if you run the report for today twice, you may get different data on the last infringement of driving duration. For example, if the driver has managed to drive 4 hours and 40 minutes by the first report execution, and 5 hours by the second, then the infringement registration time and seriousness in the first and second reports will differ. At the same time, regardless of the seriousness degree, the description “Exceeded uninterrupted driving time of 4 h 30 min” is displayed for such infringements.
Infringement The type of driver’s activity the conditions of which have been violated.
Description A short description of the infringement.
Seriousness The extent of the infringement.
Count The number of violations. If the grouping option is activated, this column shows the total number of violations for the selected interval.
Settings
You can apply the following settings to the Infringements table:
You can group the data in the Infringements table by the following parameters: total, year, season, month, week, day, day of the month, date, shift, duration. You can also sort the data in the table.
Interval filters
You can apply the following interval filters to the Infringements table:
Orders
This table is similar to the report table for a unit. The only difference is that if you add the Custom fields column to the report table for drivers or their group, you should specify the names of the required custom fields in the same-name filter. Otherwise, an empty column is shown.
Settings
You can apply the following settings to the Orders table:
You can group the data in the Orders table by the following parameters: total, unit, route, year, season, month, week, day, day of the month, date, shift, duration. You can also sort the data in the table.
Interval filters
You can apply the following interval filters to the Orders table:
SMS messages
This table shows the correspondence of the dispatcher with the driver via SMS. The dispatcher (operator) can send messages to the driver from the Wialon interface through a special SMS window. The driver sends messages from their mobile phone. This mobile phone number must be indicated in the driver’s properties.
This table isn’t available for reports on driver groups.
The columns that can be included in the table are listed below.
Column Description
Time The date and time when the message arrived.
Type The message type: sent (message sent by the dispatcher) or received (message received from the driver).
Text The text of the message.
Phone The phone number of the driver.
Modem phone The phone number of the modem that sent/received an SMS.
Settings
You can apply the following settings to the SMS messages table:
You can group the data in the SMS messages table by the following parameters: total, year, season, month, week, day, day of the month, date, shift, duration. You can also sort the data in the table.
Interval filters
Interval filters aren’t available for the SMS messages table.
Trips
The Trips table displays the location, duration, speed, and other parameters. It can include the columns described below.
Column Description
Beginning The date and time when the trip began.
Initial location The address where the device was at the beginning of the trip.
Initial coordinates The geographical coordinates of the location of the unit at the beginning of the trip (in decimal degrees).
End The date and time when the trip ended.
Final location The address where the device was at the end of the trip.
Final coordinates The geographical coordinates of the location of the unit at the end of the trip (in decimal degrees).
Driver The name of the driver assigned to the unit (only in the report on the group of drivers).
Unit The name of the unit used in the trip.
Trailer The name of the trailer (if assigned).
Duration The time interval of the trip.
CO2 emissions The amount of CO2 emissions during the trips. It is calculated by multiplying the value in the Mileage column by the value specified on the Profile tab in the unit properties.
Engine hours The time of the operation of engine hours during the trip.
Mileage The distance traveled during the whole trip.
Mileage (adjusted) The mileage taking a coefficient set in unit properties (the Advanced tab) into account.
Urban mileage The distance traveled in the urban area.
Suburban mileage The distance traveled in the suburban area (i.e. at high speed). The urban/suburban speed line is indicated on the Advanced tab (the Urban speed limit setting).
Avg speed The average speed within the trip.
Max speed The maximum speed registered within the interval.
Trips count The number of completed trips.
Consumed The volume of consumed fuel detected by any sort of fuel sensor. If several such sensors are available, their values sum up.
Rates deviation by ImpFCS The difference between consumed fuel detected by an impulse fuel consumption sensor and consumption rates. If a number in this cell is negative, it means the detected consumption does not exceed the indicated rates.
Rates deviation by AbsFCS The difference between consumed fuel detected by an absolute fuel consumption sensor and consumption rates. If a number in this cell is negative, it means the detected consumption does not exceed the indicated rates.
Rates deviation by InsFCS The difference between consumed fuel detected by an instant fuel consumption sensor and consumption rates. If a number in this cell is negative, it means the detected consumption does not exceed the indicated rates.
Rates deviation by FLS The difference between consumed fuel detected by a fuel level sensor and consumption rates. If a number in this cell is negative, it means the detected consumption does not exceed the indicated rates.
Avg consumption The average fuel consumption by any sort of fuel sensor. If several such sensors are available, their values sum up.
Avg. consumption by ImpFCS in idle run The average fuel consumption during idle run detected by an impulse fuel consumption sensor.
Avg. consumption by AbsFCS in idle run The average fuel consumption during idle run detected by an absolute fuel consumption sensor.
Avg. consumption by InsFCS in idle run The average fuel consumption during idle run detected by an instant fuel consumption sensor.
Avg. consumption by FLS in idle run The average fuel consumption during idle run detected by a fuel level sensor.
Avg. consumption by math in idle run The average fuel consumption during idle run calculated by math.
Avg. consumption by math for FLS in idle run The average fuel consumption during idle run calculated by math based on the data from a fuel level sensor (FLS).
Avg. consumption by rates in idle run The average fuel consumption during idle run calculated by rates.
Avg. mileage per unit of fuel by ImpFCS The average mileage (per one liter/gallon) detected by an impulse fuel consumption sensor.
Avg. mileage per unit of fuel by AbsFCS The average mileage (per one liter/gallon) detected by an absolute fuel consumption sensor.
Avg. mileage per unit of fuel by InsFCS The average mileage (per one liter/gallon) detected by an instant fuel consumption sensor.
Avg. mileage per unit of fuel by FLS The average mileage (per one liter/gallon) detected by a fuel level sensor.
Avg. mileage per unit of fuel by math The average mileage (per one liter/gallon) calculated by math.
Avg. mileage per unit of fuel by math for FLS The average mileage (per one liter/gallon) calculated by math based on the data from a fuel level sensor (FLS).
Avg. mileage per unit of fuel by rates The average mileage (per one liter/gallon) calculated by rates.
Initial fuel level The fuel level at the beginning of the trip.
Final fuel level The fuel level at the end of the trip.
Max fuel level The maximum fuel level during the trip.
Min fuel level The minimum fuel level during the trip.
Rank The received penalty points converted into a grade using a 10-point scoring system.
Avg value of custom sensor The average value of a custom sensor during the trip.
Min value of custom sensor The minimum value of a custom sensor during the trip.
Max value of custom sensor The maximum value of a custom sensor during the trip.
Initial value of custom sensor The custom sensor value at the beginning of a trip.
Final value of custom sensor The custom sensor value at the end of a trip.
Settings
You can apply the following settings to the Trips table:
You can group the data in the Trips table by the following parameters: total, unit, year, season, month, week, day, day of the month, date, shift, duration. You can also sort the data in the table.
Interval filters
You can apply the following interval filters to the Trips table:
Custom sensor data in the driver group report
The custom sensor data is shown in the following columns:
  • Min value of custom sensor
  • Max value of custom sensor
  • Initial value of custom sensor
  • Final value of custom sensor
If you select these columns, you must indicate the sensor name in the Custom sensor name filter. Otherwise, you can’t save the report template.
Additional possibilities
To make a report more compact and readable, you can apply grouping and configure report settings.
The Skip empty rows option is enabled by default for the Group of drivers report type. You can also generate the Statistics table, where the following fields are possible: report template name, driver name, report interval (beginning and end), and report generation time.
Tracks of the driver’s movements can be displayed on the map.
Most tables can be generated for a group of drivers.
You can’t use the Total row in the Assignments and Custom fields tables in reports on driver groups and trailer groups.
