Unit visualization
In this section, you can configure the way units are displayed on the map.
User settings dialog with the Unit visualization panel
The following settings are available:
Setting Description
Replace unit icons with motion state signs Enable this option in order to replace all unit icons by conventional signs showing their motion state. For details, see Unit on the map.
Show unit icons at map borders This option allows displaying unit icons at the map borders if the units are outside the visible area. Click on the icon to go to the unit.
Blur icons of inactive units Enable this option in order to display inactive units on the map with blurred icons.
Unit trace In order to display a track line behind a moving unit, configure the following parameters:
  • Points in trace: the number of recent unit messages which are used to display the unit trace;
  • Trace color: the color of the line which represents the unit trace. To change the color click on the icon, select the color using the color scheme, spectrum or HEX format and click OK.
  • Trace width: the width of the line in pixels.
The unit trace is visible on the map if the layer with the same name is activated.
