User group access rights
There are two kinds of access rights related to user groups:
- the rights which a user group has to other macro-objects (these rights apply to all the users added to the group);
- the rights which a user has to the user group itself.
Rights of a user group to other macro-objects
You can grant a group the rights to other macro-objects in two ways:
- on the Access tab of the group properties, if the group should get the rights to several objects at once;
- on the Access tab of the properties of a unit, unit group, user, or resource (account), if several groups should get the rights to the same object. To do this, select User groups in the drop-down list above the list of users.
How the rights of a group apply to its users
The rights granted to a user group are added to the rights of each user belonging to it. Consider the following:
- A group can extend the access rights of its users, but not limit them. If the user’s own rights and the rights of the group differ, a wider list of rights applies.
- The user’s own rights don’t change when they are added to the group, when the rights of the group change, or when other users are added to the group.
- The rights which the users receive through the group can’t exceed the rights of either the group creator or the user creator.
- When you remove a user from the group or delete the group, the user loses the rights received through the group. Their own rights remain unchanged.
Rights to the user group
Access rights to a user group allow the user to see this group on different lists, edit its properties, add and remove its users, delete the group, and so on.
You can grant users access rights to a user group in two ways: in the properties of this group or in the properties of the user who should get the rights. In the user properties, select User groups in the filter, mark the required group in the list, and select the rights the user should have to it.
As in the case of other macro-objects, the rights are divided into standard and special ones.
Standard access rights
| Access right | Description |
| View object and its basic properties | Allows seeing the group and its users on different lists and tabs. The General tab is displayed in the group properties.You can’t select any other access right without this one. |
| View detailed object properties | Doesn’t influence the access to the user group. |
| Manage access to this object | Allows seeing the Access tab in the group properties and granting the rights of the group to macro-objects. |
| Delete object | Allows deleting the group from the system. Deleting the group doesn’t delete the users added to it. |
| Rename object | Allows editing the name of the group. |
| View custom fields | Allows seeing general custom fields (that is, the ones not marked as administrative) in the group properties. |
| Manage custom fields | Allows creating, editing, and deleting general custom fields in the group properties. This access right works only in combination with the previous one. |
| View admin fields | Allows seeing the custom fields marked as administrative in the group properties. |
| Manage admin fields | Allows creating, editing, and deleting the custom fields marked as administrative. This access right works only in combination with the previous one. |
| Edit not mentioned properties | Doesn’t influence the access to the user group. |
| Change icon | Doesn’t influence the access to the user group. |
| Request reports and messages | Allows seeing the log of the group. To view the log, you must also have the following access rights:
| Edit ACL-propagated objects | Allows adding users to the group and removing them from it. |
| Manage object log | Allows seeing the log of the group. To view the log, you must also have the following access rights:
| View and download files | Doesn’t influence the access to the user group. |
| Upload and delete files | Doesn’t influence the access to the user group. |
Special access rights
| Manage user group’s access rights | Allows seeing the Access tab in the group properties, where you can grant the group access rights to system objects. |
| Act on behalf of the users within the group | Allows logging in to the system on behalf of the users added to the group, creating objects on their behalf, and performing all other actions available to them. |
| Change user group’s general properties | Doesn’t influence the access to the user group. |
