Generating activation code reports
The activation code report provides a historical log of the actions performed on activation codes: when a code was assigned to a unit, unassigned from it, or expired.
Prerequisites
To generate activation code reports:
  • The activation code feature must be enabled for your service.
  • You must be the creator of a top account or an account with dealer rights.
  • To see a unit in the report, you must have the Manage activation codes access right to that unit.
To generate an activation code report, follow these steps:
  1. In the CMS Manager navigation panel, select Activation codes.
  2. Click Generate report in the left panel. The Activation code report window opens. By default, the report displays data for today (from 00:00 to the current time).
    The CMS Manager navigation panel with the Activation codes section expanded, showing the Actions group with Manage notices and Generate report links.
  3. To change the time interval, select the dates and click Show.
Report columns
The report contains the following columns:
Column Description
Time The date and time when the action occurred.
Code The activation code affected by the action.
Unit The unit the code was assigned to, unassigned from, or linked to at the time of expiration. For top account users, this cell can be empty if the code wasn’t assigned to any unit at the time of the action.
Action The type of action: Assigned, Unassigned, or Expired.
Account The account where the unit is created. For top account users, this cell can be empty if the code wasn’t assigned to any unit at the time of the action.
Estimated expiration The estimated date of the code expiration.
Activation The date when the code was first activated (assigned to a unit for the first time).
Validity period, d The validity period of the code in days.
Sorting the report
The report is sorted chronologically by default. You can sort the report by any column by clicking on its header. Only one sorting option can be applied at a time.
You can filter the report by account, unit, or action using the search field above the table. Select a criterion type, enter or select a value, and it appears as a chip. You can add up to 5 chips in total. Each criterion type can be used multiple times: up to 5 for Account or Unit, and up to 3 for Action. If you search by several criteria, the OR logic is applied, that means, the results show rows matching any of the entered values.
The Activation code report dialog with the search field showing multiple search chips for different criteria.
Exporting the report to XLSX
You can export the activation code report to an Excel file. The exported file contains the same columns as the report. If a search filter is applied, only the filtered results are exported.
To export the report, click Export to XLSX at the bottom of the report window. The default file name follows the format: export_file_yyyy-mm-dd_hh-mm.xlsx, where yyyy-mm-dd_hh-mm is the current date and time. The dates in the exported file use the format defined in the user settings.
