Export to CSV
This option allows you to export the contents of available resources to a CSV file.
To export the resource contents, follow the steps below.
  1. In the user menu, select the Import/Export item and click Export to CSV.
  2. Select one or several resources from which you want to export data.
  3. Select the types of the resource objects which you want to export. If you mark one resource, you can expand the list of objects of each type (the button ) and select the required ones. If you mark several resources, all the objects of the selected type are exported.
  4. Click on the Export button.
The objects of one type from one resource are exported to a CSV file. In other cases, the data is exported to an archive with separate files for each type of objects. A semicolon is used as a field delimiter in the files.
