Using Geofences
Apart from the Geofences tab, you can see geofences on the map on other tabs, use them on the Monitoring tab, in notifications, reports and routes. Geofences can also be displayed in unit tooltips if the Presence in geofences option is enabled in the user settings.
| Tab | Usage |
| Monitoring | On the Monitoring tab, geofences can be displayed:
| Notifications | You can configure a notification with the Geofence entry or Geofence exit condition to receive it when a unit enters or leaves a geofence. You can configure this notification so that it is sent only when the unit speed or sensor readings are beyond the specified limits. |
| Reports | The Advanced reports module includes reports on geofences and their groups. In reports on units, you can use the following tables related to geofences: Geofences can be used:
| Routes | You can use geofences as check points when creating routes. |
