Unit on the map
The following elements can be used to display units on the map:
  • icons
  • motion state signs
  • additional elements
Unit icons
By default, a unit is indicated on the map by an icon and a caption with its name. You can select the icon from the icon library in the unit properties (for example, ), or upload your own image instead.
There are options which influence the way the icons are displayed. They are as follows:
Option Description
Rotate icon Enable this option on the Icon tab of the unit properties so that the icon rotates depending on the unit movement direction.
Display overlapping units in one icon Enable this option in the unit display settings on the map in order to replace overlapping unit icons with a common one which has a numeric indicator. You can select the common icon in the library after activating the option. For example, if six units are situated too close to each other, their icons can be replaced with this icon:
The tooltip to the common icon shows the list of the grouped units. When you click on an icon, the map is scaled so that all the grouped units are within the field of view. The unit icons aren’t grouped on the two largest scales.
Blur icons of inactive units Enable this option in the user settings so that the icons of inactive units become blurred and their captions semi-transparent.
If motion state signs are used instead of the icons, then when you enable this option, they become semi-transparent as well as the unit captions. If the Display overlapping units in one icon option is enabled and all the grouped units are inactive, their common icon becomes blurred. Also, the icons of the drivers and trailers assigned to inactive units are also blurred until they are separated from these units.
Show unit icons at map borders Enable this option in the user settings to display unit icons at the map borders if the units are outside the visible area. Click on the icon to go to the unit.
Allow positioning by cellular base stations When this option is enabled on the Advanced tab of the unit properties, its location is determined using LBS data if GPS data is invalid. In this case, the unit icons are shown as follows:
In addition, the Change icon notification action allows you to configure the automatic change of the unit icon when the conditions you select are met, such as when the device sends a specific sensor value, parameter value, alarm message, etc. For further information, see Notifications.
Motion state signs
You can replace the unit icons by motion state signs which show whether the units are moving or not. To do this, enable the Replace unit icons with motion state signs option in the user settings. The following signs are used:
Sign Description
green arrow icon The unit is moving. The direction of the arrow indicates the movement direction. The direction information is based on the course value received in the position message from the unit.
red square icon The unit is standing. If an ignition sensor is configured in the unit properties, it means that the engine is stopped.
yellow circle icon The unit is standing with the engine on (only for units with ignition sensors).
The colors of the motion state signs can be customized depending on the value of a particular sensor. This option is configured on the Advanced tab of the unit properties. In this case, the icon shape is determined by the motion state, and the color by the sensor value. The value ranges and their corresponding colors are configured in the sensor properties. If there is no data received from the sensor with customized colors of motion state signs, the default colors are applied.
Additional elements
Additional elements can be used to display units on the map. You can enable them in the menu of visible layers on the map.
The following elements are available:
Element Description
Unit trace The line corresponding to the latest movement of the unit. It is shown behind the unit icon or motion state sign. To see the unit trace, you should enable it in the user settings as well as in the menu of visible layers. In the user settings, you can also specify the trace parameters, such as the line color, width, and the number of the recent messages on the basis of which the trace is generated.
Unit name The caption (label) with the unit name. The caption is gray by default, but you can change its color on the Advanced tab of the unit properties. To choose whether the color is applied to the caption text or to its background, use the Use unit caption color for setting on the map. The caption shows up to 160 characters, including the names of the assigned drivers.
The icon to the left of the caption means that the Do not show unit location option is activated for the unit and the private trip mode has been detected.
Driver’s name The caption with the driver’s name, if the driver is assigned to the unit. The same color and color mode are used for this caption as for the unit name.
Unit movement direction The green arrow which shows the movement direction of the unit. This feature is unavailable when the Replace unit icons with motion state signs option is enabled in the user settings.
