Non-visited geofences
The Non-visited geofences table gives the list of geofences that were not visited during the indicated report period.
In the table settings, select one or several geofences. In this table you can use both the geofences from the resource in which the report template is created, as well as the geofences from other resources to which the user has the View geofences access right. The resource is selected in the dropdown list above the list of geofences. You can also select the All option for the list to contain the geofences from all the resources to which the user has the necessary access right. The geofences in the list are sorted by name. To quickly find one, use the dynamic filter.
Column Description
Geofence The name of the geofence.
Type The type of geofence: line, polygon, or circle.
Area The total area of the geofence (if the metric system is used, the area is indicated in hectares).
Perimeter The perimeter of the geofence.
Count The number of geofences that were skipped.
Description The information from the same-name field of the geofence properties.
Notes An empty column for your custom comments.
Example of a report with the “Non-visited geofences” table
Suppose, we have 4 points (geofences) that a unit should visit every day. We would like to find out whether there are geofences which were ignored within the time from April 13 to April 16. To do this, we enable grouping by data (with detalization), select necessary geofences and columns for the table.
From the table in the image below, we see that on April 13 Han1 and Han2 were ignored, on April 16 — Han4. April 14 and 15 are absent, which means that all the predefined geofences were visited on those days. You can click on the names of the geofences to move the map to their first point.
“Consider group as a whole” option
When the Non-visited geofences table is applied to a unit group, you can find one more parameter in the report template — Consider group as a whole. When this option is enabled, a group report is structured in the same way as an individual report, and the information is given for each separate unit from the group. When the Consider group as a whole option is enabled, the report structure is different — you get the list of geofences that were not visited by any units from the group.
