Data processing in Wialon
Different methods of data processing are used in Wialon. Some of them are as follows:
  • real-time data processing;
  • processing messages from the database upon request.
Real-time data processing
Real-time data processing allows for quick acquisition of data on trips, sensors, ignition, fuel, counters, speeding, and is used:
This mechanism is also used in Driving Logbook for detecting trips and their status and in Wialon for Android/iOS.
The data obtained as a result of such processing is bound to time and constitutes time intervals.
Processing messages from the database upon request
All the data sent by trackers go to the database that stores it in the form of messages. Every time the user wants to obtain summary data (for example, when executing reports or viewing tracks), a request is directed to the database and the system processes all the messages for the indicated time interval.
Possible reasons for discrepancies in results
In most cases, both mechanisms of data processing give the same results. The discrepancies might arise for the following reasons:
  • the uploaded black box messages are older than 8 days;
  • the unit properties have been edited on the following tabs: Advanced, Trip detector, Sensors, and at least 5 minutes have not passed for their automatic recalculation;;
  • the messages older than 30 days have been imported to the database (see note below);
  • different options are selected as a movement detection method and as a mileage counter (because mileage is calculated using the movement detection method in the first mechanism and using the selected counter in the second).
If you change the unit properties, the recalculation of the data processed in real time is carried out automatically in 5 minutes. In the case of processing messages from the database upon request, the changes are reflected immediately.
In case of changes in sensor settings, the data processed in real time for the last 14 days is automatically recalculated.
In case of deletion and import of messages, the recalculation begins from the timestamp of the earliest deleted or imported message, but doesn’t extend further back than 30 days from the present. If the imported or deleted message is older than 30 days, recalculation will start from one month ago instead of the message timestamp.
