Reports on trailers
To generate reports on trailers or trailer groups, the Request reports and messages access to the resource to which these trailers or groups belong to is required. Moreover, the trailer and the report template should belong to the same resource.
Tables of two types are available in the reports on trailers and trailer groups:
Assignments
This table shows the working intervals of the selected trailer if it was assigned to a unit. It comes along with the information on fuel consumed, distance traveled, etc. The parameters of this table and possible columns are the same as in a similar table for drivers, but it doesn’t contain the Violations column and columns with information about engine hours. Besides, in the report on trailer groups, a column with trailer name is shown.
Below you can see an example of the report on trailer groups with four-level nesting: trailers, units, dates/weeks/months, single assignments.
Settings
You can apply the following settings to the Assignments table:
In reports on trailer groups, the Total setting isn’t available.
Grouping and sorting
You can group the data in the Assignments table by the following parameters: total, unit, year, season, month, week, day, day of the month, date, shift, duration. You can also sort the data in the table.
In reports on trailer groups, you can also group the data by trailer.
Interval filters
You can apply the following interval filters to the Assignments table:
Custom fields
This table presents the list of custom fields created in the trailer properties. Besides, in the report on trailer groups, a column with trailer name is shown.
Settings
You can apply the following settings to the Custom fields table:
Grouping and sorting aren’t available for the Custom fields table in reports on trailers. In reports on trailer groups, you can group the data by the following parameters: total, trailer.
Interval filters
You can apply the following interval filters to the Custom fields table:
