User groups
Prerequisites
  • To work with user groups, the Users: Groups service must be enabled for the account. To create new user groups, the Users: Group creation service must also be enabled.
  • To see a group in the list, you must have the View object and its basic properties access right to it.
A user group combines users by certain criteria, for example, by role or department. The rights granted to a group are added to the rights of all its users. For details, see User groups and User group access rights.
To work with user groups, switch to the Groups mode at the top of the Users tab.
Creating user groups
To create a user group, follow these steps:
  1. Switch to the Groups mode on the Users tab.
  2. Click New.
  3. Specify the group name.
  4. If necessary, select the creator of the group in the dropdown list.
  5. In the left list, select the users you want to add to the group and move them to the right list using the icon .
  6. If necessary, configure the Access and Custom fields tabs.
  7. Click OK.
For a description of all the properties, see User group properties.
Managing user groups
By default, user groups are listed in alphabetical order. To switch between direct and reverse alphabetical order, use the icon in the list header. To quickly find the required group, use the dynamic filter above the list.
The number of users added to the group is shown in parentheses before its name. The users who don’t belong to any group are listed in a separate group called Users outside groups.
To see the users of a group, expand its row. To expand or collapse all the groups at once, use the icons / in the list header. You can’t expand groups without users. Inside a group, you can perform the same actions with users as in the Users mode.
You can perform the following actions with user groups:
Icon Action
View or edit the group properties. The available tabs depend on your access rights to the group.
Copy, that is, create a new user group using the selected one as a template.
Delete the group. The icon is shown when you point to the row of the group. It’s inactive if you don’t have the Delete object access right to the group. Confirm the action in the window that opens.
