Creating an automation
Where: Wialon Platform Studio
Automations are the presets where you define the rules and actions that are automatically triggered based on specific conditions.
Steps to create an automation
  1. In Wialon Platform Studio, navigate to the Customers page.
  2. Select a customer from the list to open their details.
  3. Go to the Automations tab.
  4. Select New automation.
  5. In the New automation form, enter a descriptive name for the automation.
  6. Set the toggle to Enabled to activate the automation immediately, or Disabled to keep it inactive.
  7. Select the Automation type from the dropdown list. The available parameters will change based on your selection.
  8. After configuring all necessary parameters for the selected automation type, click Save.
Automation types and parameters
All automation types require a set of unique condition parameters.
Sensor value
The Sensor value automation type is triggered when sensor data meets a specific condition (for example, temperature exceeds 80°C or ignition turns on).
You must have a preconfigured sensor on the device. See configuring sensors for details.
To configure this automation, follow these steps:
  1. In the Automation type field, select Sensor value.
  2. In the Sensor type field, select the sensor you want to monitor. All sensor types are available, except for the Driver identification type.
  3. In the Minimum duration of triggering state, enter the minimum duration (in seconds). Use this option to avoid false alarms from brief fluctuations or sensor errors.
  4. Set trigger conditions based on whether the sensor is boolean or numeric (see below).
  5. (Optional): Turn on the Geofences toggle and select specific geofences and geofence groups to trigger the automation only when the device is inside the selected geofences.
  6. (Optional): Toggle the Trigger outside geofences option to trigger the automation only when the device is outside selected geofences.
  7. (Optional): For the Time limitation setting, restrict automation triggering to specific days of the week and time ranges.
  8. (Optional): In the Maximum triggers per day field, enter the daily limit.
  9. Ensure the Enabled toggle is active.
  10. In the Devices to monitor section, select specific devices and labels.
After configuring the trigger conditions and limitations, you can link an action template, just as with other automation types.
For numeric sensors
Numeric sensors are those that report a numerical value, for example, temperature, speed, fuel level, or voltage.
  • Value from, Value to: Specify the lower and upper boundaries of the range.
  • Trigger outside range: Select whether the automation should trigger when the sensor value is inside or outside the specified range.
    • Inside the range: The condition is triggered when the value is strictly greater than Value from or strictly less than Value to (boundaries are exclusive).
    • Outside the range: The condition is triggered when the value is strictly less than Value from or strictly greater Value to.
For boolean sensors
Boolean sensors report one of two states, such as on and off for ignition or fastened and unfastened for a seatbelt.
Sensor value: Select the state that should trigger the automation. The dropdown options correspond to the specific states of the selected sensor (for example, On or Off).
Schedule
A time-based trigger that activates on a recurring schedule. Configure the following parameters for a Schedule automation:
  1. In the Expression field, enter a cron expression. Use the Syntax reference on the right to create an expression manually. To use the scheduling examples:
    • Find the necessary period in the Scheduling example description.
    • Click on the example to copy it to clipboard.
    • Paste the example to the Expression field on the left.
  2. Ensure the Enabled toggle is active.
Connection loss
The condition is triggered when a device fails to send data to the server for a specified duration. To configure the automation:
  1. In the Name field, enter a descriptive name.
  2. For the Type, select Connection loss.
  3. In the Minimum duration of triggering state field, enter the minimum duration (in seconds).
  4. (Optional): Turn on the Geofences toggle and select specific geofences and geofence groups.
  5. (Optional): Toggle the Trigger outside geofences option to trigger the automation only when connection loss occurs outside the selected geofences.
  6. (Optional): For the Time limitation setting, configure specific days of the week and time ranges.
  7. (Optional): In the Maximum triggers per day field, enter the daily limit.
  8. In the Devices to monitor section, select specific devices and labels.
Logical expression
The most flexible automation type. You can create complex, multi-layered conditions based on available telemetry data. Configure the following parameters for a Logical expression automation:
  1. In the Name field, enter a descriptive name (for example, Engine malfunction).
  2. For the Type, select Logical expression.
  3. Fill the Expression to trigger alarm using the hints with possible functions for your expression and helper text in the tooltips. As you are entering an expression, click the appropriate function name to autocomplete the field. Create a logical expression using the section on the right. This section helps you find the necessary parameters and logical operators to join them into an expression. Learn more about the logical expression format.
  4. In the Minimum duration of triggering state, enter the minimum duration (in seconds).
  5. (Optional): Turn on the Geofences toggle and select specific geofences and geofence groups.
  6. (Optional): Toggle the Trigger outside geofences option to trigger the automation only when connection loss occurs outside the selected geofences.
  7. (Optional): For the Time limitation setting, configure specific days of the week and time ranges.
See the examples of setting up automation workflows on the pages:
Private mode enabled
The Private mode enabled automation type is triggered when Private use mode is enabled for a device (for example, by a hardware switch or via the Manage private use widget in Wialon Platform FleetSpace). Use this automation to notify responsible users or start an internal automation workflow when a vehicle switches to private mode.
  2. In the Type field, select Private mode enabled.
    private mode enabled automation
  3. (Optional): For the Time limitation setting, configure specific days of the week and time ranges, for example, Monday to Friday.
  4. (Optional): In the Maximum triggers per day field, enter the number of times the automation should not exceed per day.
  5. Ensure the Enabled toggle is active.
  6. In the Devices to monitor section, select specific devices and labels.
  7. Click Save.
When linking an action template to this automation, you can use placeholders in the Text field to insert dynamic values, for example, device name, time, address. See Using placeholders in the text message.
Form assigned
The condition is triggered when a new form is assigned to a driver or device.
Select the devices to which this automation applies.
Form overdue
The condition is triggered when an assigned form passes its deadline without being completed.
Form rejected
The condition is triggered when a completed form is reviewed and rejected by a manager.
Form with failed check
The condition is triggered upon completion of a form if one or more form items were marked as failed.
Tachograph download due info
The Tachograph download due info automation type warns you before the deadline for downloading tachograph files: every 28 days for a driver card and every 90 days for a vehicle unit. The deadline is counted from the last file received from this driver or device. To see the deadlines of all drivers and devices in one place, use the Due dates tab.
To configure the automation, follow these steps:
  1. In the Name field, enter a descriptive name, for example, Driver card download due.
  2. In the Type field, select Tachograph download due info.
  3. Select what the automation monitors: Device or Driver. Your choice defines the deadline, the objects you select, and the available actions.
  4. Enter how many days before the deadline you want to be notified: 1 to 90 for devices and 1 to 28 for drivers. If you leave the field empty, you get the notification on the day of the deadline.
  5. Select the devices and labels, or the drivers, to monitor.
  6. Ensure the Enabled toggle is active, and click Save.
Then link an action template, as with other automation types. See Creating an automation workflow.
If you monitor drivers, only the actions that don’t need a device are available: Send online notification, Send an email, Send Telegram message, Send push notification to driver, and Send push notification to user. If you monitor devices, the actions that work with a device are available as well, such as Execute a command, Assign a label, or Create a service.
The system checks the deadlines once a day and triggers the automation only once for each deadline. The next reminder for the same driver or device becomes possible after a new tachograph file is received. This type has no Time limitation and Maximum triggers per day settings.
The automation works only for the drivers and devices that have at least one tachograph file. If no file has ever been received, there is no date to count the deadline from. To get the first files, request them manually or configure automatic file requests.
Tachograph live issue
The Tachograph live issue automation type is activated when the tachograph detects that a driver is approaching or has exceeded a driving time limit defined by EU Regulation 561/2006. Use this automation to notify dispatchers and drivers about compliance warnings and violations in real time.
To set up this automation, configure two additional settings:
  • Select source: Choose the tachograph card slot to monitor: Slot 1 or Slot 2.
  • Select issue: Select one or more compliance issues that should activate the automation and click Add to confirm the selection. The available issues correspond to the issue states shown in the tachograph live table.
New service
The condition is triggered when a new service is created in the Maintenance module. The automation is useful for creating notification chains.
Service due info
The condition is triggered based on the maintenance schedule of a device, used for sending service reminders. Configure the following parameters for a Service due info automation:
  2. For the Type, select Service due info.
  3. In the Service plans field, select the relevant service plans.
  4. Choose one or more conditions:
    • Days left or overdue
    • Mileage left or overdue
    • Engine hours left or overdue
  6. In the Devices to monitor section, select specific devices.
Form submitted
The condition is triggered when a form is submitted. To configure the Form submitted automation:
  2. For the Type, select Form submitted.
  3. Ensure the Enabled toggle is active.
  4. In the Devices to monitor section, select specific devices.
You can use the Form submitted automation to track whether drivers submit a required form before starting a trip.
Workflow example. This workflow example shows how you can detect cases where a trip begins before the required form is submitted. To configure the workflow, follow the next steps:
  1. Create a Schedule automation and link two action templates to it: Create a form and Assign a label. In the Assign a label action template, specify the Form not submitted label. When a form is assigned according to a schedule, the automation will create and assign a form and set the Form not submitted label for the selected devices.
  2. Create a Form submitted automation with the action Assign a label. In the Assign a label action template, specify the Submitted label. When the driver submits the form (regardless of the result), the Form submitted automation switches the device label to Submitted.
  3. Then, create a separate automation that can monitor vehicle movement and notify you if a trip starts while the vehicle still has the Form not submitted label. For example, a Logical expression automation with the speed parameter associated with the Send online notification action.
Logical expression format
The Expression to trigger alarm field in the Logical expression automation requires a mathematical or logical expression that uses telemetry parameters. Browse the right part of the window to find the necessary parameters and operators. Learn more about logical expressions in the flespi documentation.
For example, if your device’s GPS reports a speed greater than 10 km/h and its ignition status is off, the logical expression is: position.speed > 10 && ignition == false
You can combine multiple conditions using logical operators:
Arithmetic operators
  • + (sum): Adds values.
  • - (difference): Subtracts values.
  • * (multiply): Multiplies values.
  • / (divide): Divides values.
Logical operators
  • && (logical AND): Both conditions must be true.
  • || (logical OR): At least one condition must be true.
  • ! (NOT): Negates the condition.
Equality operators
  • == (equal): Checks if two values are the same.
  • != (not equal): Checks if two values are different (inverse of ==).
Comparison operators
  • > (greater than)
  • < (less than)
  • >= (greater than or equals)
  • <= (less than or equals)
  • () (parentheses) define the order of logical operations
Example expressions
  • engine.oil_pressure < 10 (if oil pressure drops below 10 units)
  • engine.temperature > 100 && vehicle.speed > 0 (if engine overheats while moving)
  • battery.voltage < 11.5 || engine.blocked.status == true (if battery low or engine is blocked)
See more examples of setting up automation workflows on the pages:
