Setting up fleet telemetry
Where: Wialon Platform Studio
The Telemetry setup page in Wialon Platform Studio helps you standardize data collection across large and diverse fleets. By creating reusable configurations, you can streamline the process of onboarding new devices and ensure that telemetry data is consistent and accurate.
The page is available in the Resources section of the navigation menu.
You can apply a telemetry preset on the Data step of the device creation wizard. If the model of the connected device has a linked preset, the platform applies it automatically. Otherwise, default sensors are created. See Creating devices.
Telemetry setup involves two main components:
  • Telemetry presets: Collections of sensor templates that are applied to specific device models. When a new device of a selected model is created, it automatically inherits the sensor configurations from the preset.
  • Sensor templates: Reusable configurations that define how to interpret a specific data parameter from a device, including its name, unit of measurement, and calculation formula.
Creating a telemetry preset
A telemetry preset links your sensor templates to specific device models, automating the sensor configuration for newly connected devices. Creating telemetry presets is efficient for large-scale management as you can create sensor templates within the preset and link them to the device models within a single workflow.
  • You can’t add more than 100 telemetry presets.
  • Each device type is only associated with one telemetry preset.
To create a telemetry preset:
  1. Expand the Resources section and open the Telemetry setup page.
  2. Switch to the Telemetry presets tab.
  3. Click New preset to create a new preset.
  4. Enter a Name for the preset (for example, Standard vehicle sensors)
  5. (Optional): In the Description field, enter information about the preset.
  6. Click Save.
  7. Navigate to the Device models tab.
  8. Click Assign to models to select the device models to which this preset will apply. You can select multiple models from the list.
  9. Navigate to the Sensors tab.
  10. Click Add sensor template to choose existing sensors with the configured sensor templates. The sensors are now linked to the telemetry preset.
  11. Click Save to finalize the preset.
Once the telemetry preset is saved, any new device created with one of the assigned device models will automatically be configured with the sensors from this preset.
You can check the number of linked device models in the Devices column of the telemetry presets list. Hover over the number to see the list of device models in the tooltip.
Creating a sensor template
You can create sensor templates within device properties and on the Telemetry setup page.
You can’t add more than 100 sensor templates
To create a sensor template on the Telemetry setup page:
  1. In Wialon Platform Studio, open the Resources section.
  2. Open the Telemetry setup page.
  3. Switch to Sensor templates.
  4. Click New sensor.
  5. Enter a name for the sensor template.
  6. In the Sensor type field, select a sensor type, for example, Engine temperature.
  7. In the Formula field, enter the expression.
  8. Click the Measurement unit field and select the unit.
  9. If necessary, add validation.
  10. Click Save.
The created template is now available to be added to a telemetry preset. You can also access this sensor template on the Sensors tab in the device properties.
You can check the number of linked devices in the Devices column of the sensor templates list. Hover over the number to see the list of devices in the tooltip.
Default sensors
Default sensors work as regular sensor templates. You can recognize them by the word Default in the name, for example, Default Ignition. Only one template is created for each sensor type (one default ignition, one default acceleration, and so on), and it’s reused for all customers of the service provider. The following sensor types can be created as default sensors:
  • Default Acceleration: Measures the rate of change in velocity (in m/s2 or G).
  • Default Battery level: Measures the tracker battery charge (in % or kWh).
  • Default Engine hours counter: Tracks the total duration the engine has been running.
  • Default Engine temperature: Monitors the engine coolant temperature (in °C or °F).
  • Default Ignition: Monitors the status of the vehicle’s ignition (On or Off).
  • Default Mileage counter: Tracks the total distance traveled by the vehicle.
  • Default Voltage: Measures the electrical system voltage in volts (V).
Creating and editing default sensors
The platform can create default sensors automatically if you select the Create default sensors option in the device creation wizard. You can also configure them manually on the Telemetry setup page and on the Sensors tab within the selected device.
When you assign a default sensor template, it replaces the existing sensor of the same type.
You can edit a default sensor the same way as a regular sensor template. Devices that get the template after your changes use the edited version.
