Configuring device telemetry
This guide will walk you through the process of configuring device telemetry to translate raw data into meaningful, visually structured information.
Telemetry data is all the information collected from your devices, such as speed, temperature, voltage and others. This information is collected in Sensors. To make setup easier, you can create sensor templates to apply the same data configuration across multiple devices.
Configuring and visualizing sensors includes the following tasks:
Setting up device telemetry
Sensors define how the platform interprets the raw parameters sent by your devices. You usually set them up when connecting hardware: on the Data step of the device creation wizard, you apply the telemetry presets of the device models or create default sensors. In this case, your devices already have sensors, and you can go to Setting up device profiles.
To add or adjust a sensor for a single device:
Select the device on the All devices or Devices tab on the Customers page. Use quick search to find the device by name, ident, phone number, plate number, or VIN.
Go to the Sensors tab.
Select a sensor type on the left, for example,
Ignition. -
In the Settings section on the right, select an existing sensor template in the Sensor template field or select Create new at the bottom of the list. See Creating a sensor template.
Click Save.
To apply the same sensors to all devices of a model, use telemetry presets. For the full guide, see Setting up fleet telemetry.
After configuring sensors in Wialon Platform Studio, you can customize how it is displayed in Wialon Platform FleetSpace.
A device has two configurable views:
- Device list: Overview of all devices.
- Device details: Details of a single device.
You can use chips and widgets to customize both views.
- Chips: Small, color-coded indicators for at-a-glance status.
- Widgets: Larger blocks that display detailed data, often with charts.
Customizing the device list
The device list is customized with chips for quick, real-time summaries. Sensor chips provide quick summaries of each device’s key stats, helping you spot issues at a glance.
To add a telemetry chip:
Log in as a customer and navigate to the Devices page.
Click the icon
in the sidebar to enable the editor mode. For more information on the editor mode, see the page Using editor mode. -
In any device row click the Add widget slot.
Locate the Sensor chip and click the icon
in its row. -
In the Sensor type field, select the sensor type you’ve just set, for example,
Ignition.
Enable the option Use sensor name as title to use the default sensor name, or disable it to give a custom name to the chip.
Under Thresholds, define the icon and color for two states: on and off.
Click the icon
in the top-right corner of the window to add the telemetry chip to the device’s row.
Now you can monitor the vehicle ignition in the devices list. You can add multiple sensor chips to monitor other data.
Learn how to add other widgets to the device list on the Setting up widgets in the device list page.
Customizing the device details
The device details shows a device dashboard with chips (summary data) and widgets (detailed data such as speed, temperature, ignition, and voltage).
To add a chip:
- From the device list, open the device details.
- Click the icon
in the sidebar to enable the editor mode. - In any top row click the Add widget slot.
- Add the Sensor chip as described above.
To add a widget:
Click Add widget in the device details body.
Select a widget (for example,
Telemetry cell).
In the new window, select a Size for the cell, which determines how much space it occupies.
Select a Parameter system name from the dropdown menu. This is the data point you want to display (for example,
position.satellites). -
You can optionally enter a Unit of measurement for the parameter.
Provide a Title for the telemetry cell (for example,
Satellites). -
Click the icon
in the top-right corner to add the telemetry cell to the device’s row.
Now you can view satellite data in a cell within the device details main body.
Learn how to add other widgets to the device details on the Setting up widgets in the device details page.
Using telemetry data on the Track player page
The Track Player page visualizes historical trips with event icons generated directly from telemetry data. These icons mark critical occurrences such as speeding or harsh driving.
You can customize the data displayed on the Track player page using the editor mode.
